Originally posted by hiho
View Post
239mm 10mm thick solid disc (Diesel Std) use pad DB-128 18mm thick
239mm 12mm thick solid disc (Petrol Std) use Pad DB-105 14.8mm thick
239mm 20mm thick vented disc (GTI Std) use pad DB-242 15.3mm inner & 17.3 outer
256mm 22mm vented disc (16v Scirocco) use pad DB411 15.8mm thick.
Caveat: I pulled this info from the Bendix catalog which isn't always right.
Diesel and Petrol Calipers can be the same with different pads to accomodate for disc thickness.
There's also a DB-145 listed for Petrol Golf but I've never seen this one in the wild
Sometimes the DB-128s don't work on the diesel discs, if in doubt the DB-105s are the safe bet, they'll work in either.
Audi 80 Calipers from 1978 - 1990 use pad DB-401 and bolt up to the MK hubs and work with the 239mm vented 20mm thick GTI discs.
Pete
