R32 brake conversion on Bora V6 4Motion
  • R32 brake conversion on Bora V6 4Motion
    Hi all,
    I've got the R32 calipers and rotors. Do I also need the R32 carriers?
    Cheers!
    Nothing to see here...
    yep you do the bad news is if you dont have them they cost 300 more from vw new
      i have a full set up for 1k if you want them due to the fact i cant find wheels i want
        Personally i wouldn't bother with the R32 set far too heavy,if you are going for serious power and need brakes to match then go for a leon cupra R set up or some nice porsche stoppers.
        VF Stage1 Supercharged V6 4motion Bora
          I already have the calipers and rotors - will need to check if the carriers are attached. The comment on weight is absolutely right -they're hideously heavy. Not only that, they're hideously expensive too - $580 each from VW in Australia at trade prices...
          On the carries, for a change VW in Australia may be comparably priced to overseas - ECS want USD$213 each for them.
          William: What wheels are you after?
            Good news - I appear to already have the carriers (I thought they were a separate item to what I have, but they're actually part of the assembly I've been referring to as the caliper.
            w00t!
              Further to this - apparently I need the longer R32 brake lines - rather than going for OEM rubber ones, I'm looking for ADR-certified braided lines. Are there any local manufacturers I should look at?
                The thing being with the R32 carriers is that they "correct" your front arm geometry for a lowered car as the spindle height is different, my Jetta 4 motion had lowered springs and the front arms were at quite a big upward angle really affecting the handling.
                I installed R32 struts, uprights, driveshafts and arms to "correct" everything, amazing difference!
                  yuppe for me already have r32 stock springs and dampers
                  Audi B4 80 Q V6'94 Race Car !! KEGGED
                  Audi B4 80 V6 Avant'94 Only one in the country that I know of !!! KEGGED
                  Subaru Forester XT'06 Genome Exhaust/Car-PC/Boost Gauge/Oettingers !
                  --VW Bora V6 4mo'01 Gone
