Can your VW run on E10?
  • Can your VW run on E10?
    Plug the chassis number in here and VW will tell you:
    E10 < Service & Zubehör < Volkswagen Deutschland
    PM if you are looking for: R32 rear sway bar; R32 suspension springs; Euro Headlight switches
    Keep in mind that whatever ethanol blend you use, the research octane number (RON) must be 95 or higher.
      This website is mainly for European Consumption, while some VINs may pass through (mine did) I would be wary of putting E10 94 in my car as it is not recommended by VW.
      As Diesel_vert said it should be 95 RON and qualify with DIN 51 626-1.
      - Ben
      2008 Jetta 2.0L FSI
