VR6 engine oil?
    Originally posted by ScienceVR6 View Post
    during the summer months i use a 20w 50, as in australia, the tempriture is much higher than in germany where they decided on what oil to use.
    I did compition motocross for a while, and getting the wieght of the oil right for the conditions made a huge differance to the life of the motors.
    The hotter it was, the heaver oil we used. The bikes where air cooled, so tempriture was important.
    Two different engines, air cooled need heavier oil, i use castrol 20w 50 in my oval, but way to heavy for a VR6 motor. 10w40/ 15w40 is recommended.
    1st place Mk3 Standard 08
      If you look at oils solely on the viscositys in regards to tempriture, a 10w 40 or a 15w 40 arn't nearly heavy enough, they turn to water in the heat. i basically don't trust them to look after my motor on a 35 degree day when the engine oil temp is 115 degrees
        So by that token, 10w-30 in the summer, 15w-40 in winter???
          I think the other way around.
            yeah, in summer you need a thicker oil couse it thins out in the heat.
