What gearbox oil to I buy for GQM (02S Family) Gearboxes ? apart from Genuine any recommendations ?
1 of 2
2 of 2
Penrite Manual Gear Oil70 or SIN Gear oil 75 check it at Penrite website.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Originally posted by Transporter View PostPenrite Manual Gear Oil70 or SIN Gear oil 75 check it at Penrite website.
(2006 Golf 1.9 TDI 6 spd man)- Ben
2008 Jetta 2.0L FSI
Originally posted by Diesel_vert View PostThe VW part number for your transmission is G 052 171 A2, so look for that on the label or data sheet - it may help you decide which non-genuine oil to buy.
Penrite recommends Manual Gear Oil 70.- Ben
2008 Jetta 2.0L FSI
Originally posted by phaeton View PostHi M - the Penrite site says refer to dealer when I go to the search site and put all the details in, your the 2nd tech I know though that has said Sin Gear oil.
(2006 Golf 1.9 TDI 6 spd man)Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Originally posted by Transporter View PostDon't use Penrite Manual Gear Oil70 if their Datatec lube guide says refer to dealer. They most likely changed the make up of that oil and is no longer valid for that application. I use Penrite for some time now and I know that for sure from the Penrite rep.- Ben
2008 Jetta 2.0L FSI
The 02S gearbox (6-speed manual) uses different oils depending on the gearbox code. Some use G 052 171 A2 as I previously mentioned, while others use G 052 512 A2 - which is half the price and explains Brendan_A's experience.
If anything, it should say "Refer to dealer" for the Golf 118TSI because it uses G 052 512 (unless Penrite Manual Gear Oil 70 is also compatible with G 052 512).
Originally posted by Diesel_vert View PostThe 02S gearbox (6-speed manual) uses different oils depending on the gearbox code. Some use G 052 171 A2 as I previously mentioned, while others use G 052 512 A2 - which is half the price and explains Brendan_A's experience.
VW says to use G 052 171 for gearbox code GQM, and Penrite's datasheet for Manual Gear Oil 70 (dated May 2012) says it can be used where G 052 171 is specified.
I use Manual Gear Oil70 in my 2005 T5 6speed manual (different g/box though) and it shifts fine - it's too filled for life, but I drained it at 20,000km and since than I change oil in it every 20,000km .Last edited by Transporter; 08-06-2012, 08:43 PM.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Originally posted by Transporter View PostIf you want to use it, than call Penrite Technical helpline 1300736748 to check if that is still valid.
Test Slow
