Guys, the time has come for the brake fluid to be replaced.
Any ideas on a good fluid to use?
Or stick with the OEM stuff?
Most VAG models from 2006 onwards use a low viscosity brake fluid, in order for the electronic stability control systems to work optimally at low temperatures.
As such, the workshop manual says the brake fluid must conform to VW TL 776 Z and hence meet VW 501.14
You don't have to use the genuine fluid, but as we are not in Europe, alternatives are few and far between on the local market.
Does anyone know where to buy a vw501.14 compliant fluid? Id prefer ATE but can't find it anywhere.
any DOT 4 fluid will do, but given that you have a nice BBK, I would at least use Penrite Racing RBF600 or Motul RBF600 fluid and change it every 6 months.
Mitsubishi Pajero Sport - Super Select 2WD/4WD Toyota 86 GTS Performance Pack Moon Slate - RWD MINI Cooper S Clubman - FWD
oops, sorry I mistakenly read ongti's signature as richmurphy's... any dot 4 is fine, penrite super dot 4 is prob better.
So I've just ordered ATE SL.6 from HSY today for my Passat B7 V6 4Motion Highline as VW also specifies the need for VW Standard 501.14 brake fluid in my car. Ordering from HSY was very easy and they were very helpful. So thanks to HSY.
And thanks for the info
Initially, it was somewhat of a challenge finding a suitable non OEM fluid. And at the end of the day I'm not sure it's actually going to make much of a difference. The boiling points of the VW OEM fluid are dry 265°C / wet 170°C. The ATE SL.6 is dry 265°C / wet 175°C.
In my search for information though I found these threads that others might also find interesting:
- Car and image Forum
- Jaguar Forums
It seems the primary difference with the VW standard is the need for a low kinematic viscosity at -40°C of <750 or <700 cST. This seems to be the ISO 4925 Class 6 standard. Many DOT 4 fluids only meet the ISO4295 standard or other classes. Although I haven't been able to find a reference to the standard to find out the specifics.
I'm not sure how much of a difference this will make in Australia. Perhaps if you live in the cooler regions where we get sub 0°C temps it might benefit your ABS system over a higher viscosity fluid. Considering we're talking about a system that can be responsible for saving our life though, I'm not sure I want to risk the use of a product that doesn't meet this spec.
So it seems some other brake fluids that meet this VW spec are (links to manufacturer info where possible):
