Ok guys so tell me. Why is BP the best fuel. My Golf R is 6 weeks old and I've only ever put Shell V Power in it.
Why BP
differnt producers own the refineries in different states, so in WA, BP refinery makes the BP Ultimate and its the best.
Shell for example either buy BP fuel and re-label it, or they import from singapore and so there are question marks about quality control during storage and handling.
Each state is different, so I;'d suggest you work out who manafactures the fuel in your state and work from there.
List of oil refineries - Wikipedia, the free encyclopedia2007 Audi RS4 with: APR ECU Upgrade; JHM Quick Shifter; Milltek Catback and Downpipes; KW V3 Coilovers; Argon Creative Carbon Fibre Splitters
BP apparently has a cleaner fuel and does better over longer periods of time.
This was covered before so if you search you should find all you need.
Hope to see your R out and about at our meets.
i use to use shell 98, i was $hite.... then i switched to BP 98, never going back.
getting better fuel economy and more power:S
the old Shell fuel years ago was brilliant!!! but since they changed the formula to this new c%^*
i reckon it goes:
1. BP/Mobil
2. Caltex
3. Shell
just because shell is the most popular (amount of stores), doesn't mean its the best
I find over here in Newcastle this is opposite.
In my MR2, I got 150km's less consistently driving like a grandma with BP ultimate. Compared to V-power with a good boot full every so often. The car felt more responsive mid range to with V-power..
This is an interesting topic and every time it is covered one sees lots of opinions posted that seem to be based on perception rather than reality. One only has to look at where oil refineries are located in Australia to see what happens, oil companies horsetrade with each other to give them the ability to operate nationally.
Caltex
Lytton Brisbane
Kurnell Sydney
BP
Kwinana, WA
Brisbane
Mobil
Melbourne
Shell
Geelong
Sydney (Soon to be closed)
Below are a couple of exerpts from the ACC enquiry into the petrol industry in 2007, it demonstrates that the oil companies have various joint supply arrangements. Personally I don't feel any difference running BP, Mobil, Shell or Caltex and as is demonstrated below the Mobil silverwater terminal is supplied by pipeline from both Shell and Caltex!
Caltex
Caltex has access to 22 seaboard terminals around Australia, some of which are owned and operated
by Caltex and others are in some form of joint operating arrangement with other parties. Caltex did not
indicate at which of these terminals it could import cargoes of unleaded petrol.
In Victoria Caltex has capacity for the storage of refined products at the Newport terminal, which it
owns and operates. Caltex also has a hosting arrangement with Shell at its Corio terminal.
In New South Wales, Caltex owns and operates terminals at Banksmeadow and Newcastle. It also
has storage capacity at the Silverwater terminal, which is operated by Mobil through a joint venture.
However, the Silverwater terminal is supplied via pipeline by the Kurnell refinery and Shell’s Clyde
refinery.
Mobil
In Victoria Mobil frequently imports cargoes into its Yarraville terminal. Mobil operates the Yarraville
terminal through a joint terminal arrangement with BP. The capacity of the Yarraville terminal is 31 ML.38
Mobil stated that it supplies its product requirements in Tasmania from Shell under buy–sell
arrangements whereby fuel is generally sourced from Shell’s Geelong refinery. Mobil uses BP’s
terminals at Burnie and Hobart and Marstel’s Bell Bay terminal under joint ownership or long-term
throughput arrangements.
In New South Wales Mobil imports into the Vopak terminal via a throughput arrangement. Mobil has
a joint terminal arrangement with Caltex for access to a terminal at Silverwater. However, Mobil stated
it does not import into the Silverwater terminal because it is supplied via pipeline by Caltex’s Kurnell and
Shell’s Clyde refineries. Mobil also has a joint terminal arrangement with Shell at Newcastle, but does
not import into that terminal because it is supplied via pipeline from Sydney.41
Mobil does not regularly import into Queensland because it sources supply from BP and Caltex
under buy–sell arrangements. Mobil has throughput arrangements with BP in Cairns, Townsville and
Mackay, and with Caltex at the Gladstone terminal. Mobil has a joint terminalling arrangement with BP
at Whinstanes terminal in Brisbane. However, as mentioned above the Whinstanes terminal is not an
import terminal and is supplied via pipeline by the Caltex and BP refineries.
In Western Australia Mobil imports into the Coogee Chemicals terminal in Perth.
In South Australia, Mobil accesses the Birkenhead terminal under a joint venture arrangement with
Shell, under which Mobil operates the terminal.44 Mobil also has access to a terminal under joint
ownership or long-term throughput arrangements with Shell at Port Lincoln. Shell operates the Port
Lincoln terminal.
They are all in bed with each other.
Cheers George06 Jetta 2.0TFSI Killed by a Lexus!
14 EOS 2.0 TSI has arrived!
George, I dont think "they are in bed with each other".
Its economies of scale.
For example, the WA market isnt big enough for two refineries to be operating - one or both would go bankrupt. So one runs the refinery and the others buy from it, rebrand, mix their own additives etc etc.
some are now directly importing product from singapore to try and compete.
BP has the refinery in Perth and is typically the most expensive fuel.
The Shell/Coles or Caltex/Woolies fuel is typically a lot cheaper - this behaviour reflect competition and not that they are bed with each other.2007 Audi RS4 with: APR ECU Upgrade; JHM Quick Shifter; Milltek Catback and Downpipes; KW V3 Coilovers; Argon Creative Carbon Fibre Splitters
I buy Caltex only and if really need fuel I'll get BP. I know both are the same but prefer Caltex as they are always the cheapest!
If you really want to know, Caltex on Wellington St in Perth City, right next to Wellington Square is the cheapest everytime! Around the corner are 3 other Caltex stations and is at least 10 cents cheaper then the others! It's crazy and have no idea why! I buy 95 and put it in the 6R Polo GTI I have and can't tell Difference between 98 and 95 when I got the car besides price!! Same usage and same amount in a full tank cept ones slightly cheaper! I used "Premium" at Shell in my previous car, a French car and holy cow that was chewed up so fast!! Then they introduced V Power but havent tried it...
I'm sticking with Caltex, specially the one in the city!!! Everytime.[FONT=Franklin Gothic Medium]Matt
2015 Skoda Octavia RS | Combi | DSG | Metallic Grey | Tech Pack, Every Option Except Leather |
Prev: 2012 VW Polo GTI | 5dr | DSG | Reflex Silver | RCD510 |
I only know of one Caltex in my general area, and two BP's that are further away (never drive past them though), so I stick with VPower. I've noticed that if I mix SVP and BPU I'll get great performance, but a few trips later after filling up with BPU the car feels very sluggish, so I tend to avoid it. Might just be those particular servos in my area.
funny how different cars get different results.
just topped up with V Power, see how it goes... haven't tried it in at least 6 months
Don't disagree with you Gareth, economy of scale is a huge issue for refiners in Australia and is the major reason that Shell is closing the Clyde refinery, our refinieries are very small relative to the rest of the world. I read a story a few years ago about a refinery under construction in India that when completed would have greater capacity than all the refineries in Australia combined!Originally posted by gareth_oau View PostGeorge, I dont think "they are in bed with each other".
The point I was making is that the oil companies have co-operative arrangements to enable them to operate nationally without having their own refineries.
As for Coles and Woolies well yes the fuel is cheaper but they offset against their grocery pricing and their strategy is to tie people to both fuel and groceries.
