I've done a fair bit of work with cars coming in and out of our workshop that we've set up to run not just e85 but dual mapping for both e85 and 98. It's a LOT easier with a fuel system that runs at 37psi at idle compared to a fuel system that runs 30bar like it does on a current model Golf. For those who may not know, 1 bar is equivilent to 14.75psi so fuel pressure is extremely high when talking direct injection.
It's easy to replace a fuel pump with a larger pump, or even twins as long as you arent talking about a car with cam driven fuel pumps, and injectors on lets say a subaru WRX or an Evo is perhaps a 20 minute job, injectors are easy to find, easy to install andeasy to dial in. For a VW/AUDI it's around a 5 hour job, no jokes and dialing them in isnt easy.
The amount of current drawn from an injector like you'd find in an RS4 is huge too, but then you'd expect that when fuel pressures get as high as 150bar! All in all, e85 with it's high fuel consumption under load makes it VERY difficult to use in a direct injection car. Believe me, I'm trying my hardest to come up with a solution as e85 is easy power.
It's resistance to knock is acceptional and as far as increases in power... It's phenomenal! The amount of timing you can add makes any car just sing, especially down low. It makes Torque simply come alive. To give you an example, with just a fuel pump and injectors change, dumping 98 and replacing it with e85 I've seen an Evo making 280kW at the wheels go to 347kW and over 100Nm.
