hey guys, in my current state of unemployment, i was wasting time cruising the net, when i stumbled across a thread in tdi club. i've lifted some pretty meaty information regarding too-frequent oil changes, and pumpe duse engines:
Shame on the prior owner for changing at 5k miles interval. Since you are not experiencing any problems, follow the recommended oil change interval for your car.
Originally Posted by Blue02JettaTDI
I do 5-6k oil changes. Theyre cheap and easy to do.
Originally Posted by NB_TDI
Way to fail.
Originally Posted by Drivbiwire
And three times the wear rates on a car that cannot afford them.
The owners whos PD's I tend to, are trying to recover the money they put into the car as a result of incorrect oil usage. Now that the motors are running properly and wear has been eliminated as a future issue we are doing what we can to reduce the wear and maximize the life of the engines.
They like the fact that they can safely run 15,000 plus miles between changes and have wear rates that are so low that even they see a need to go to 20K. Of course this is backed up by an occasional oil sample (not every time) but typically every 3rd to 4th oil change. This only serves to validate our oil change intervals.
Running a PD motor in a perpetial state of detergency has got to be the worst thing you can do to these motors. You want to allow the dispersants to do the job of keeping an engine clean and not continually flush it with detergants. Ever look at the hands of somebody with OCD, not pretty now imagine what is going on in your motor. By changing every 5K the additives have just started to stabilize and now you dump the oil and spike the detergants again? Not a smart thing to do no matter how cheap and easy that oil change may be.
You know what is cheaper and easier? Leaving the correct oil in the motor and going 15K, lower wear, higher reliability and less work and money.
Of course if you want to throw money away and increase wear by all means there are plenty of us standing by ready to rebuild the head on your PD motor and serve you with a bill for around $2000 depending on the extent of the damage you did.
I'm not 100% sure if my case is the reason, but the previous owner did OCI's every 5-6k per "the dealer" until i bought it w/ 183k. Now at 217k, a compression test yielded very low compression (barely w/in spec). I would say it's plausible that the shorter OCI's caused faster wear of the piston rings than normal. Not to mention, after 50k miles if you change every 5k you've paid for 5 extra oil changes.
interesting! the thread is here:
Changing the oil to often? - TDIClub Forums
makes for good pondering... any opinions/ experience, guys?
Way to fail.
