VW 505 01 Engine Oil
  • VW 505 01 Engine Oil
    The following Engine Oils meet the VW 505 01 Specification:
    Mobil Synt S Special V 5W-40
    Mobil Synt S Special V 5W-40 is a high performance diesel engine oil using a synthetic based formulation. It is primarily intended for use in Volkswagen pump-jerk diesel engines where an oil approved by Volkswagen to their specification VW 505 01 is required. These engines are filled on production with an oil of this quality.
    This is the only oil I have found so far to meet this spec in Australia. I will continue my research.
    Australian VW Caddy Forum
    http://www.getphpbb.com/phpbb/index....um=dutchaussie
    Australian VW Caddy Website
    http://VW-Caddy.yolasite.com
    Have you looked at the Fuchs range of synthetics for TDI's and FSI's ?
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
      I have read the name before but have never seen any of their oils in Australian shops.
      I will do some more research.
      I am looking for oils meeting the VW 507.00 spec for our 2007 VW Caddy.
        you are not going to find any. It is specially made by Castrol for VW and it is not available for retail.
        I have tried
        GOLF V 2.0 TDI COMFORTLINE
        SAY NO TO INTERNET FILTER http://www.getup.org.au/ http://nocleanfeed.com/
          It's a specification not a brand.
            I have tried
            This true as I've been through the same scenario with my bro's GTI.
            Apparentely VW has a deal with Shell oil now as that's what I've been told by my friend at VW.
            Obviously Shell made a better offer. This happened to BMW awhile ago when they converted to Castrol from Mobil & all the product's had to be replaced.
            I your after info on what oil to use, check here in the lube section. These are all for the Mk5 GTI
            Castrol
            CASTROL EDGE SPORT 5W-30
            Castrol Edge Sport 5W-30 is a full synthetic SAE 5W-30, API SM/CF. ACEA A3/B3/B4 engine oil formulated for highly tuned fast fours and latest technology engines. It provides superb strength and ultimate protection even when running hard, fast or hot.
            Service Refill Capacity: 4.6* Litres (See Note 56
            Shell
            SHELL HELIX ULTRA 5W-40
            Mobil
            MOBIL 1 0W-40 or MOBIL SYNTH S 10W-40 or MOBIL SUPER S PLUS 10W-40 or MOBIL 1 0W-40
            Hope his clears up a few thing's & help's out.
              Yes, but for diesel engines there aren't any oils with same specs that you can find in retail shops.
              You can buy it from a dealer for around $25.00/L. but for topping up purposes you can use fully synthetic 5W-30 or 0W-30
                Buy it in 5 L, it is cheaper.
                Performance Tunes from $850
                Wrecking RS OCTAVIA 2 Link
                  I haven't tried to buy any yet I just know this 'cos dealer offered it to me when i was picking up my car
                    Yes, I recently found this brand.
                      VW 507 00 Oil
                      Have a look at my Website & Forum for information.
                        Nulon 5W-40W is 505 compatiable... a bit pricey but so far so good on a 1.9 TDI
                          It must be VW approved not a compatiable. It is not the same.
                          Shell Helix ultar extra from Repco is on special $79.95
                          Stick with oils from the oil companies it is safer.
                            sorry it is approved www.nulon.com.au
                              Meets or exceeds the high performance specifications of the following vehicle manufacturers:
                              BMW long drain LL-98, LL04
                              Mercedes Benz 229.51
                              VW 50200, 50500, 50501
                              Porsche Approved
