Squeaky shifter - any lube recommendations?
  • Squeaky shifter - any lube recommendations?
    hi VWW'ers
    Not sure if it was a combo of my ham-fisted install of my short shifter or if its just normal wear and tear, but my shifter now makes a very annoying chirp when I shift - particularly from north-south.
    Anyone know a good grease/lube/solution to fix it? driving me nuts.
    I'd suggest you check it is not rubbing on anything Dylan. Get the MRS in the car and stick your head in to see what it is hitting/where it is coming from.
    As for lube, I would use silicon spray, but I may be told im wrong.
