Originally posted by Jmac
View Post
Penrite Oil
Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
I have been using Penrite HPR15 on the Little Beastie for a couple of years and I get great performance and usage out of it. When I had the big road trip over xmas, during both high heat and then high humidity, the car did not use a drop of oil and it is still opaque and viscous. I am due for an oil change on the 14th Jan, but I am under the 5000ks, I will still do the change anyway. Excellent value for money,and Australian as well.Old Skool Passat Power Rules!!!
1974 Passat LS with a SEAT 1.8, 32/36 Weber, full performance exhaust and a K&N filter. 80kw at the wheels??
Originally posted by Transporter View PostYeah, I know Grego,
but I have more trust in VW505.01 approved ELF Solaris than any other oil that meets or is made to VW 506.01 or 507.00 specs. (Penrite HPR5 Diesel 5W40 and similar).
and should it come to it, that there is no longer VW506.01 oil to buy, we will have to start using 507.00 oils or what I call “a fake” 506.01 oils. In that case I would go with ELF Solaris or Penrite HPR5 Diesel 5W40 and the dose of LiquiMoly MOS2 additive.
Generally I’m against additives in oils but in the case of VW R5 engine I use LiquiMoly additive from 64000km on, in my engine. I hope, I never need to prematurely replace the camshaft and rockers.
Wait till i introduce a new chip alternative this year hehehe armidillo suit on order hehehe.
Have fun and i take no offence really only trying to help . been with the brands for moons and tried very hard to stick by what they approve.
JmacAlba European
Originally posted by Transporter View Postand should it come to it, that there is no longer VW506.01 oil to buy, we will have to start using 507.00 oils or what I call “a fake” 506.01 oils. In that case I would go with ELF Solaris or Penrite HPR5 Diesel 5W40 and the dose of LiquiMoly MOS2 additive.
Before deciding if I was prepared to use VW 507 00 oil in my AXE (2.5 TDi 174 PS) engined VW T5, I...
According to that 507 is actually BETTER than 506.01, so you may not need to add MoS2 to use 507 into your early R5 engine.
I've read a few reports on R5s that were burning a fair bit of oil when filled with 506.01, then when the owners switched to 507 the engines burnt significantly less oil.
Jmac, I see no need for flame suits, just a healthy exchange of opinions, no "bagging" that I can see.
The more information people have, the better quality choices thay can make re what oil to put in their vehiclesLast edited by gregozedobe; 11-01-2010, 02:07 AM.2017 MY18 Golf R 7.5 Wolfsburg wagon (boring white) delivered 21 Sep 2017, 2008 Octavia vRS wagon 2.0 TFSI 6M (bright yellow), 2006 T5 Transporter van 2.5 TDI 6M (gone but not forgotten).
Originally posted by gregozedobe View PostHave you seen the info re anti-wear properties of 506.01 vs 507.00 from Lubrizol as set out in this Brickyard thread ?
I wonder, if it is the viscosity 0W30 of the VW506.01 that is more important for early R5 engine, since the VW don't want to use VW507.00 in them.
I looked at the wear scars in that article from Lubrizol and one has to remember that for the 0W30 oil to get the same results in anti-wear protection the anti-wear additives must be tougher (better or maybe “a different” is probably a better word) than in 5W30 oils.
Any way it is good to know that 507.00 oils are as tough as 506.01, less worry for the future.
Originally posted by Jmac View PostWow i didnt realise there was potential to have don a flame suit on the fuel and lub section, only offered help with any Penrite questions not a bagging of it. Itll clearly never change , use what (you ) feel the need to use and each to their own i suppose.
Jmac
What I meant was that, my T5’s owner’s manual allows VW505.01 and since the ELF is approved for that,
it is a logical choice to use it before Penrite's - made to specs (not tested/not approved) oil.Last edited by Transporter; 11-01-2010, 03:42 PM.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Cant be helped sometimes im sure you understand when you read some of the drivel
Peace
JmacAlba European
Originally posted by Jmac View PostFair call from you both, glad to see a conversation about it and not just which oil is best routine like normal, i might have jumped a bit and thats just the gaelic blood firing through my veins guys im up for topic like the rest but have had the haunches up a few times on here but chill pill in order
Peace
Jmac
Did you try any of the Sonax product, yet?Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Originally posted by Transporter View PostI wonder, if it is the viscosity 0W30 of the VW506.01 that is more important for early R5 engine, since the VW don't want to use VW507.00 in them.
I think the anti-wear additives are the crucial ingredient in 506.01 oils.
The lower cold viscosity in 506.01 might help with cold starts and lubrication at start up with the freezing temps they are getting in Europe and northern USA lately.
My theory on why VW hasn't officially approved 507 for the early R5 motors is simple economics - that particular variant of the R5 engine is no longer made and there are not many of them in use, so not much demand for oils for them, therefore not worth spending the money to go through the approval process for 507 oils.
Originally posted by Transporter View PostWhat I meant was that, my T5’s owner’s manual allows VW505.01
I have read quite a few oil manufacturer's "which oil" guides for T5s, and I don't recall seeing 505.01 mentioned as suitable for R5s.
Personally, if I had an early R5 engine (I don't), I would be more comfortable using a "made to spec" 507 oil than with a "VW officially approved" 505.01 oil, especially if going the full 12 months/15,000 km between services and/or if there were a significant number of short journeys in the driving regime. Probably wouldn't matter either way with shorter change intervals and wholly longer journeys. But that is just my opinion
As I've said before, it is up to each individual to gather all the relevant info and make the choice they believe is best for their circumstances.2017 MY18 Golf R 7.5 Wolfsburg wagon (boring white) delivered 21 Sep 2017, 2008 Octavia vRS wagon 2.0 TFSI 6M (bright yellow), 2006 T5 Transporter van 2.5 TDI 6M (gone but not forgotten).
Also, see my earlier post on this thread regarding UOA's on 507 oils. The jist of it being 507.00 oils show a lower wear rate than 505.01 (in 4-cylinder TDI's).
So while real world data shows 507.00 is better than 505.01, I don't know if you can extrapolate that data to R5 engines.
IMHO I don't think it matters what you use - 505.01, 506.01, 507.00, "approved", "meets/exceeds", whatever - just use what you're comfortable with and if the engine dies from poor lubrication, submit a claim to the oil manufacturer.
One thing Volkswagen need to do though, is to stay off the crack.
Originally posted by gregozedobe View PostAFAIK the 0W vs 5W is the viscosity (flowability) at low temperatures, and the second 30W is the rating for hot oil, so there is no effective difference between the two as far as viscosity goes once the engine is warmed up.
Do you know if 505.01 is currently approved for your engine ? I ask because VW have been known to change oil approvals for engines well after the date of after manufacture, thus rendering "no longer accurate" the info in the owner's manual that came with the vehicle.
VW505.01 approved for my R5 also means that the oil was tested in no. of T5’s and was approved at the time for 12months/15,000km. Why did they later change it to VW506.01 I don't know, it could well be because of the worn out valve train components when people were changing oil at 15,000km intervals, I change my oil at 7,500km or 6 months, no later. The 506.01 oil was approved for 2 years or 50,000km (not in OZ) when I bought my van and what they say now? Is it 30,000km?
But regardless of the speculations, I always keep the stock of VW506.01 oil for my T5, so it is very unlikely I will have to use VW505.01 or VW507.00 in it.
At the moment I plan on keeping that van for another 5 to 10 years and even if it last that long, I can't say it is because I changed oil every 7,500km (too small test sample, 1 vehicle).Last edited by Transporter; 12-01-2010, 01:40 PM.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Thanks for that Ben.
Wow, Euro 1,340 for approval that lasts for 2 years !!!!!
Now I know why some oil containers say "meets" rather than "approved".2017 MY18 Golf R 7.5 Wolfsburg wagon (boring white) delivered 21 Sep 2017, 2008 Octavia vRS wagon 2.0 TFSI 6M (bright yellow), 2006 T5 Transporter van 2.5 TDI 6M (gone but not forgotten).
The rep also told me that a Workshop in SA services the T5 Campers from KEA with Penrite and has VW Approval.
Also asked about DSG oil the rep said its being developed but will be a while before it arrives.- Ben
2008 Jetta 2.0L FSI
JmacAlba European
Hi Jmac,
You asked if someone tried Sonax brand.
Today I received some Sonax car care products and I just tried their wheel cleaner (ordered 5L of it, since Penrite rep showed me how it works). I cleaned wheels on our Touareg in less than 10min. The product is ph neutral, smells nice and just sprays on leave 5 min and hose off. The best wheel cleaner I've ever used!
Also tried/bought Glass Polish, Clearview windscreen washer additive (in 5L very economical), Glass cleaner (in 10L well priced). All good.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
