I have no idea and google talks about some pad cleaners that tbh if i don't see them on CCP then i don't buy them.
how does one clean buffing pads?
I was at one of the clinics yesterday and Michael used this Car Care Products / Edge / Car Accessories / Buffing Pads / Tool - Pad Conditioning Brush
took the dry powder & dust off a treat.sigpic
GTI MY16.5 PURE WHITE | LAKIN PLATE HOLDER | TINTS |
i caught a video somewhere that showed people getting a MF towel and basically grabbing the pad whilst it was on a slow (1) rotation setting and sort of cleaning it that way? I dunno.MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
Whilst doing the car still you use the pad conditioning brush. This will take all the old polish off the surface of the pad and leave you with a clean buffing area.
When the car is finished I spray mine down with some APC (like Mint APC for example) let them sit for 5 mins then give them a really good rinse under the tap with warm water. Keep rinsing and squeezing until only clean water comes out. To dry them off lay them flat in a warm area or, like me, put them in the dryer.
This method leaves you with brand new pads each time that will last longer and perform better than pads that are just spurred then put away.
If you need to 'clean' (unclog from too much polish) pads while you are in the middle of polishing then a Pad Cleaning brush, that has stiff nylon bristles is good and likewise a good blast from a compressor can blow out the dust and polish.
Once you have finished the job or the day, then we simply put them in a bucket with warm water and some APC (or if you do not have this, dishing liquid usually works) leave them to soak for 30mins and then wash them out under runnning water until clear. Squeeze out the majority of water and then put them on your polisher, over a bucket, and spin them off to remove more water, then leave to dry - they should be good to go again the following day.
Some of our pads have been washed out 30-40 times and are still fine.
Edit: Started writing this reply an hour ago, got distracted and after posting saw Dan's...Car Care Products Australia
www.carcareproducts.com.au - 1300 006 007 - info@carcareproducts.com.au
Sydney - Brisbane - Melbourne
Excellent, thanks guys. I am pretty sparing with my polishes, but after doing my headlights the week before and not cleaning my pads I then attacked the bonnet of my car and figured my pads to be clogged.
Just to check, are the pads clogged when you start to get too much dusting?MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
Not necessarily clogged, just full of old polish. The dust is the abrasives in the polish, which are usually suspended in the oils, but as the oils are dried up the abrasives go everywhere
is it dangerous to have the dust everywhere? Or just unsightly?
I thought the Menzerna range were low dusting anyway, so I think i'll be cleaning my pads after every session regardless.MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
Just annoying. Menzerna is very low dusting when your using them, but if you let it dry out, that's out the window. Its the same for every polish
Car wash isn't strong enough to break down the oils that are present in the polish. That's why some APC is recommended. You could also use dishwashing liquid.Originally posted by D3bb4 View Postbucket of water and a cap full of car wash... massage the pad till it's clean. (for foam)
