window tinting
  • window tinting
    hi vdubbers,
    has anyone tried window tinting???? any help would be good!! its only for the bizza so not too concerned...
    i watched the whole process of them doing it on my previous car..
    looked pretty easy, just need to be careful wen cutting it with the blade.
    they spray soapy water on the window then put the film on it wen its still wet so it can move around to get a perfect fit, then using this tool they slide over the window and presses all the water out wen it drys, its done.
      Similar process I used with my rear taillight tint. Works really well. Don't know if this should be done with tint as well, but I had a blow-dryer next to me to make it easier to shape - might distort the clarity of the tint.
      Present: Mk3 Golf variant.
        the main prob is dust and dirt
        they will leave white dots
        use baby shampoo with water in a spray
        bottle . scrub window clean then start spraying
        at top and work down so it will flood off any extra
        dirt . most use outside of glass as template just
        leaving it slightly bigger. have it very wet when
        putting on film makes it easyer to position
        use something like a credit card but softer so as not to
        scratch film ,work from middle out to remove water
        have window down 10mm trim top edge wind up and
        finish bottom. don't wind down for a few days
        hope that helps haven't done it for 10 + years
          A few Q's on tinting...
          I recall seeing in the glossy that the Jetta windows (presume same for the other models) have a "Heat Insulating Tinted Glass". Didn't get a straight answer as to how much tinting the glass comes with as standard.
          1) In particular, will adding "Midnight Express" - advertised as darkest legal tint - together with the standard VW factory thermal tint stay within the 35% limit?
          2) Is it legal to apply a clear tint to front windscreen to reduce internal reflections from the dash?
          3) Does applying a metallic-based tint to the glass mounted radio antenna greatly reduce the reception?
            1) nope
            2) As far as im aware you are not allowed to put and tint on the front window, but you'd think a clear tint wouldnt count?
            3) yes it does be careful
              Removing old Tint
              The tint on my Mk2 is starting to peel and bubble, is probably as old as the hills anyway.
              Im thinking of peeling it off and getting it redone eventually, my question is, if i I peel it off, what gets left behind? Any nasty adehsives I have no chance of getting off? Or should i let the tint company remove the old stuff?
              Dont mind driving around with no tint for awhile if im able to get the glass cleaned up.
              1986 MkII Golf GTI 16V (Sold), 2005 MkV Golf GTI (Sold), 2007 Polo GTI (Sold), 2011 Polo 66TDI (Selling), 2012 Passat 125 TDI Bluemotion, 2013 Scirocco R (Due October!)
                To answer my own question...
                Will give this a try...
                http://www.tintdude.com/remove.html
                  i seriously think just get someone to do it, the guy thats done my tints has done 4 of our cars, mobile service, $200 for 15% tint. i just dont think its worth running around buying tint and all that kinda stuff unless ur a DIY type of bloke.
                  2004 GTI, GIAC, DOWNPIPE
                  2007 R32 3DR MANUAL
                  2010 NAVARA D40
                  2016 Q7 4M 200kw
