OK, I'm an originality nut. Probably due to my nostalgic disposition. When I bought my Mk1 there was no parcel shelf. I asked the dealer, "Who traded her in?" He gave me the guy's 'phone# so I rang him and sure enough the old shelf was in his shed and you can guess the condition! Picked it up but checked out ebay and ebay UK motors but good parcels shelves are becoming hard to find, and expensive to buy and ship. So I decided to have a go at the old one. Didn't take any pics but the reason it was dicarded was bad damage to the edges where it rests on the fixed side shelves, carpet torn off, "hinge" destroyed, no hangers and just generally poor. I'm surprised the previous owner didnt take it to the tip.
First job was to repair the carpet and torn/broken/split composite material.
I had to choose the right glue so I trialed a variety on small pieces of split shelf. Contact adhesive, PVA and Araldite. Surprisingly, PVA came out best. I penetrated the shelf well, set hard and dried clear, but after gluing I still didn't trust the repaired shelf edges for strength. Out came the tinsnips and I cut two pieces of galv. steel sheet that were lying around the diary workroom. These were then shaped and bent so that the fitted the contours of the edge of the shelf. The strips were then pop rivetted to the metal strip at either end of the shelf. Before fixing I applied contact adhesive to ensure a good bond to the shelf.
Next I used contact to stick the carpet back onto the composite. Luckily, there were few tears and no holes, so this went really well.
I used some "Export" black aerosol to spray paint the underneath of the shelf and then turned my attention to the "hinge". Placement of the carpet and black-and-white elasticated straps is crucial to getting the shelf to sit right and the hatch to close without jamming it so I spent some time playing with it until I got it right. It's important to contact the carpet to the rear edge of the metal strip of the shelf. After this, I bought some hangers from an ebay seller for $4 and the shelf is a goer! Ok, so it's not absolutely original but it works and you would have to peer closely underneath to see the metal strips.
(If you have any restoration or repair stories it would be great if you could spend the time to post them. You could be really helping someone!)
