Hi all - I've noticed that the soft plastic/paint (not sure what it is) surface around high usage areas of the car is starting to peel and it has a sticky(!) feel to it. Particularly on the centre console area near the radio and around the gear boot - it seems to have worn through to the plastic underneath.
I'm not sure what it is that covers these surfaces (vinyl paint?) or how easy it is to fix. I seem to recall a thread on here where someone was stripping the parts back - how did that go? Has anyone been successful in re-coating their interior plastics and what did you use?
Cheers,
Lachlan.
Cheers,
Lachlan.
but i just rubbed it on some fine sandpaper to give it and edge slightly better than a fingernal and started scrapping. You dont have to remove all of it as once you have scorred it you can use mothers plastic pollish and it will cleen it up really well.
