Lowering a Yeti
  • Lowering a Yeti
    Has anyone had any experience with lowering a Yeti. I find the space for the wheels (17inch) looks somewhat oversized...
    ...and its really hard to wash the roof without a chair to stand on.
    2014 MY14 Corrida Red Elegance Wagon TDI
    2009 MY10 Race Blue RS Wagon TSI 6 sp. manual. (Gone)
    2011 MY12 Yeti 77 TSI DSG.
      Puzzled why you'd want to do this
      Isn't greater ground clearance a feature?
      I'd suggest buying an Octavia...
      2006 VW Golf GTI Silver Mk5 5dr manual no options (the way nature intended) SOLD
      2012 Skoda Octavis RS wagon, race blue, red stitch interior, DSG SOLD
      2008 Skoda Octavia vRS Wagon (Mk II, pre-FL) 2.0 TFSI 147Kw 6 MT bright yellow SOLD
      Other: 2013 Mercedes B250 Sliver Command Pack panoramic roof
        It's my understanding the lowering springs / shocks to suit the Tiguan will suit the Yeti.
        I'm thinking of doing it too, given the reality I offroad like - never, might as well make it a road burner.
          Stand on the back wheels, works for me.
            Lowering a Yeti
            Yes I have lowered mine. Used golf r springs I bought second hand. Nice and stiff around corners especially with a thicker rear sway bar from a golf gti.
            Welcome back to Instagram. Sign in to check out what your friends, family & interests have been capturing & sharing around the world.
            Because mine is a 2wd 77tsi, and I wanted it to handle more to my tastes for the majority of my driving.
            2012 Yeti 77TSI, Candy White
            ydad.com.au: musings of a dad growing up - the blog.
            cbay.com.au: photography, video, design - creations.
              Cool great tip, looks perfect to me!
              Just be aware the GTI / R rear sway will only suit the 2WD models, you need a 4x4 Tig etc version for the 4x4 to get around the rear haldex diff. I've my sights set on a Whiteline one for a Tig.
                Cheers Cbay - looks nice! what was the approx cost of this conversion all up?
                  Go the Superpro. The way the whiteline is secured (locking collars around the swaybar mounts) leaves something to be desired. The mounts will come loose and the bar will slide; and start clunking. Awful design!
                  Not including hers...
                    some some coilovers and set whatever height you like!
                    pretty much anything to suit a PQ35 chassis will fit. just be careful if you need 50mm or 55mm front struts
                      What mk model golf R coils did you use? are the coils from mk6 and mk7 the same? and would the coils then suit the 4x4 yeti as you said you have fitted them on your 2wd.
                      thanks,
                      Dev.
                        Sorry for late response, from memory it was shy of $400 (time/labour), I also had second hand a rear sway bar from a golf GTI fitted at the same time.
                        Springs second hand < $100
                        Rear sway bar second hand = $50
                        Alignment < $70
                          thanks,
                          Dev.
                          I received springs from a mk6 R, and I think they would more suit the 4x4 (up front) than the 2wd.
