How have others found the reliability of the Skoda Yeti Ambition 90TSI?
The MY14 Skoda Yeti Ambition is ideal for my needs and I really love it. However there has been a few issues and I have not had a warranty claim on any new car (Japanese, British, German built) since the late 1980's except for the VW Polo I had prior to the Yeti. The Yeti is not even 2 years old and has less than 10k mileage. Since this is based on the Golf Mk V platform with recent tech updates, I would have thought it would be a well sorted stable design.
There's been nothing major but not what I would have expected from a new car these days (I understand other brands have issues as well).
* DSG hiccups at times with holding onto gear at a constant rev and not changing up for a few seconds - dealer check and no error logged (no fix)
* Instrument panel creaks - dealer attempted fix but still creaked - self repair with 2mm felt placed at offending areas
* Full throttle failure on several occasions where engine would not spool up for a few seconds - dealer check and no error logged (no fix)
* Whirr noise LH front when on RH curves - dealer replaced wheel bearing - self organised tyre rotation and and 4 wheel alignment (better but still present)
* RH front headrest creeps up to unsafe height - dealer no fix - self repair velcro tie headrest to seat
* Doors occasionally failed to unlock via KESSY - dealer advised CAN BUS can go to sleep if not used for a while - self fix change battery in remote
* Dash lights disappearing in daylight (not the dark tunnel effect) - corrected itself
* Whistle noise in engine bay TPI2041310/4 - dealer changed water pump and seal
* Ticking noise heard through vent on dash when car stopped after normal use. Sounds like a tappet noise or a vacuum pulse or non return valve ball banging on the seat. Doesn't do it cold and when happens, disappears after engine shutdown and restart. Just started so will leave for the next service next month.
As I said nothing major but still concerning as I wanted to keep the Yeti for 6 years. The service dealer have been very good and have listened to my concerns. Some they fixed, others not but I'm not complaining as they have made the effort.
