Originally posted by romaniac
View Post
At a guess, 8.5" / ET57 will have the tyres scraping against the struts on the front if the factory offset on a 7.5" rim is ET46 as you will be 24mm closer to the strut. From my experience, there is usually only about 15mm maximum to play with. If you are going from 7.5 to 8.5 then you'll have to stick with ET46 as that will make the rim 13mm closer to the strut (& 13mm closer to the edge of the guard as well). If you are trying to fill the guards, ET57 will change nothing visually.
You need to check the following before committing:
- Check the tyre placard for the minimum load rating currently allowed - don't go less than this.
- Check tyre placard for maximum diameter rim fitted - don't go more than +2" over this.
- Check fitted rims for ET stamped on rim.
- Check physical clearance between rim/tyres & body or suspension
- Feed the above figures into an offset/tyre fitment calculator to make sure it all works. I have a really good one but this forum doesn't allow you to attach excell files. There are a few out there on the internet too.
