<rant switch ON>
It's frustrating to pull up at the diesel bowser, get out of the car, and start to fill her up when you realize that you have pulled up to the high-flow pump and the nozzle won't fit into your Skoda's fuel filler tube properly.
You glance across to the only other diesel bowser in the garage, a low flow one, and there is some buffoon using the petrol nozzle.
Aaaarrgggh.
So you persist and you get 0.015 litres of diesel into your tank before the auto-shutoff triggers. You gently squeeze the trigger of the nozzle, about 0.2mm so it won't happen again, but it inevitably trips off and now you have 0.020 litres in your tank. So on it goes on until you can't bear it anymore, and you go and pay for that hard earned 10 litres of fuel you have just added.
Now a couple of observations/questions:
1. It doesn't really matter because the vehicle is so fuel efficient, it will be a long time before you have to visit a bowser again.
2. Do Skodas have smaller diesel filler nozzles than other brand diesels? I know my old Land Cruiser had a whopping filler tube and high flow pumps weren't a problem. What about Audis or Mercs or even Hyundais?
3. Who do I speak to in order to get more diesel bowsers installed?
4. Why on Earth do people insist on using the petrol nozzle of the only diesel bowser in the garage when there are 15 other dedicated petrol bowsers available?
5. Why are there so many stupid people who think you must pull up to the bowser the same side your filler tube is on. People, the hose will reach onto the other side.
<rant switch OFF>
There, I feel better now. I was going to kick the cat when I got home but I couldn't find it, so this post is resultant. Most cathartic, thanks for bearing with me.
Aaaarrgggh.
<rant switch OFF>
