Superb mirror not tilting in reverse
  • Superb mirror not tilting in reverse
    My curb side mirror is not tilting when reversing. This option is ticked in the setup menu on the MFD but it still doesn't tilt.
    Dealer says this is normal for an Australian car and that the manual is wrong. I'm not convinced.
    Has anybody else come across this?
    I may have the answer
    Hi Black Superb,
    If my knowledge is up to scratch i think you need to make sure the power mirror toggle switch is turned to the L (for left mirror adjustment). The car will not enact the feature unless it is pointed to the L before putting the car in reverse.
    Once you have put the car back into park the mirror will automatically return to its original position.
    See how you go, if this doesn't do the trick then maybe it's something we have to explore a little further.
    Regards
    Chris
      Yes indeedy you are correct. Thanks Chris.
      It tilts nicely but doesn't quite return to its original position. That's OK, at least it works.
      Maybe I (and my servicing dealer) should
        It should return to its normal position when you achieve a certain forward velocity... It's not immediate when you take it out of reverse...
          I seem to recall reading somewhere that you have to select L on the mirror control, put the gearbox in reverse, then adjust the mirror while it is in the "down" (curb viewing) position so it knows exactly where to point to when you select reverse.
          And if you use different keys some options are key specific.
            Everything the others said plus the mirror gets lazy & doesn't quite come back all the way and requires occasional recalibration.
            I just had a Vauxhall Insignia (?) Elite hire car for 19 days with mirror tilt & it would be great for 2 days then suddenly get brewers droop & require adjusting.
