Škoda SuperB Wagon: make the suspension stiffer?
  • Škoda SuperB Wagon: make the suspension stiffer?
    Hi all, I wonder if anyone has ever "tuned" their suspension to be even more stiff then they are now in the "sport" mode. To me the car is still rolling to a side, bit more than I'd like it to. I know the ride will be a bit harsher but that's exactly what I want.
    Any recommendations who has done it / could do it? I've asked the Skoda service but the guy I talked to almost laughed. Cheers
    Replacement springs and/or rear swaybar is what you will need.
    The stiffer rear swaybar will help reduce the rolling on corners but will have no other effect on the ride.
    Springs will also help reduce the rolling on corners (lower centre of gravity plus stiffer than original springs) but will also have an effect on how the car rides.
    B9 Audi SQ5
      I've added Eibach sports springs and a H&R rear arb to my Superb Sportline Wagon. Transforms the handling, corners much flatter and no understeer. Height drop was about 25mm. Ride comfort is similar to before, Although I also changed my wheels to 18' and 45 series tyres rather than 40, which I think helped with the brittleness of the OEM tyres. Very happy with the result of all this.
        i too have the Eibach Prokit springs installed. It's dropped mine by 20mm.
        I also have the Hardrace rear sway bar.
        Combined, the swaying & wallowing have dramatically reduced.
        Bouncy bounce is less.
          Thanks for all the responses, will go with just the rear swaybar first and see how it goes. I don't want to lower my car just yet, but the same height springs just bit stiffer would be handy (any ideas?)
            Guys, can you post the link where you sourced the swaybars from? Looking at the Hardrace website for Skoda SuperB V8, there are only FWD versions. Does the same swaybar applies to AWD that I have? Cheers
              Rear anti roll bars differ between fwd and AWD. So get the right one.
                AWD = Hardrace 8778
                FWD = Hardrace 7759
                  May I ask specifically which H&R arb did you fit?
                    You can get custom springs made at the std ride height but stiffer.
                      any links pls ? I've just fully loaded the car for camping + 3 bikes at the towball, I look like I'm moving the whole house lol. Very interested.
                      Anyone else has any resources for rear springs, stiffer than the stock ones, but at stock height or higher?
                      cheers
                        cheers
                        I work for a company called Infrabuild (used to be called OneSteel and many years prior it was BHP) and we sell Aussie made spring steel round bar in bulk to aftermarket spring manufacturers such as Lovells, King Springs, Dobinsons and Monroe etc. These are made into springs for passenger vehicles, 4wd and trains etc. Perhaps contact some of these companies to see if they can offer you what you want.
                        B9 Audi SQ5
                          cheers
                          Rears off a Superb Scout (or Passat AllTrack, etc) should be 15mm+ taller. They might be called the "Rough Road PAckage"
                          King Springs, Lovells or K-Mac were the custom spring makers when I was in the industry.
                          Or https://www.spaccer.com/en_AU/makes-...erb-iii-kombi/
                          Or Car Spring Bumper In The Spring Buffer Cars Auto Buffers Shock Absorber Power 2 Pcs Auto buffers Cushion Urethane For Cars Goods|Shock Absorber Parts| - AliExpress
