2020/2021 Maps are available now
  • 2020/2021 Maps are available now
    Update portal
    24GB
    Need a VIN for that Dont if you go here https://www.vwwatercooled.com/foruml...ml#post1315342 and a direct link to map file provided courtesy of FLipperDog
      Thanks Hillbilly.
      Tig 162 R-Line; Audi TT
        Ditto - to CaffineAU and Hillbilly - downlaoded and in car. All good. Many thanks
          Thank you for the reminder.
            Hi all, newbie Brad here from Sydney. Recently bought a Skoda Octavia Scout Premium 132TSI MY16, which I am loving so far. However I seem to have fallen foul of the Bermuda triangle that is how to update the maps (current version is 2019/20). I successfully downloaded the 2020/21 version to my Mac via the update portal, using the VIN number. There was no Skoda SD card that came with the car, so I formatted (ExFat) a 32GB Sandisk SD card and inserted into the SD slot as per the "It is easy" video on the update portal page. The system recognised the card, but refused to update (got an error message to check the source etc.). I then tried a Samsung USB drive (ExFat); got very excited when the system recognised the drive with a "System update" message. This is it I thought...but no. Same deal, system attempts to update then I get the same error message. Any suggestions gratefully received!
              Use a PC Macs stuff up the way it is written on the card and thats your problem
                wat Hillbilly said.
                i've updated plenty of times with my SD-CARD (formatted as FAT32) with no issues.
                  Thanks Hillbilly, I did wonder if it was a Mac/PC thing. Sadly we're an all-Mac household, might have to press the neighbours into service...
                    Its actually the unzipper it uses if I remember correctly
                    Come in from the Dark Side LOL
                      Thanks for the unzipper tip, I tried again using WinZip for Mac and that did the job.
                      Not leaving the Dark Side just yet ha ha...
                        Hi
                        I have a 2018 Superb with the Columbus.
                        When I enter my VIN into the portal it says there are no updates. Should I at least see 2021 map?
                        thanks
                          Looks like the system is down ATM, I just tried a couple of VINs with the same result.
                          Flipper Dog
                          Now - T-Roc R, Audi Q5
                              Go here then Volkswagen Map Updates VW and Skoda maps are the same except for file names
