Speedometer Error?
  • Speedometer Error?
    After following my wife home recently I asked her why she kept sitting below the speed limit, to which she replied she was doing the speed limit. I then decided to check my speed against phone GPS, two different phones and two different apps all showed my speedometer seems to read about 2km/hr low at 60 and up to 6km/hr low at 100. Since my car how the wheels changed over by the dealer from 18 to 19 I suspect there maybe some adjustment that wasn't made. Can anyone else with the 19in Xtrem wheels please let me know if their speedometer is accurate?
    Cheers,
    Karl
    MY18 Passat Alltrack Wolfsberg (white) darkest legal tint (SOLD), 2014 Golf 110 TDI Highline (sold after DM Flywheel issues), now 2021 RAV4 Cruiser Hybrid, 2020 C-HR Koba Hybrid
    I think from factory most new cars from about the mid 2000's travel 5% under the actual speed showing on the speedometer. I dare say it's to help prevent speeding. My old Honda Accord Euro travels 5% under it's actual speed that it reads and has the original 17" wheels on it. Anyone please correct me if I'm wrong
      They're always out by around 10km/h at 100.
      Easy enough to compensate for, but it's nice to have a bit of fudge factor there, around town.
      '07 Transporter 1.9 TDI
      '01 Beetle 2.0
        You guys are not understanding, my car is showing a lower speed than it is doing...
          Yes, going slower than what's on the Speedo is normal these days.
          '01 Beetle 2.0
            In my Golf 7, I went through the same process. Bottom line I would set the cruise to 120 in a 110 zone and drive through the speed traps no worries 👍
            Sent from my HTC_0P6B using Tapatalk
            132 TSI Tiguan Black with Drivers assist and Luxury Packs.
              No, when my car shows 100 it's doing 106!!
                When the speedo shows 60 it's doing 62-64 and when the speedo shows 80 it's doing 84-86, when the speedo shows 100 it's doing an actual 106-109
                  I'd check the tyre size, sounds like the rolling diameter is too big. The OZ standard allows for speedo error to be under by (Don't quote me) 10%, there is no over tolerance any more.
                  2012 MY11 Cappuccino Superb Elegance, TDI. (Gone)
                  2014 MY14 Race Blue Octavia Ambition Plus wagon, TSI, Tech Pack. (Wife's)
                  2014 MY14 Cappuccino Octavia Elegance hatch, TDI, Sunroof, Tech Pack, Towbar. (Gone)
                  2017 MY18 Lava Blue Superb wagon, 162 TSI, Sunroof, Tech Pack, Comfort Pack, Cream Leather, Towbar (Mine)
                    Which model? The cause is likely wheel diameter for inaccurate measurement. Speedo will need calibration if you plan to keep the wheels.
                    Sent from my HTC_PN071 using Tapatalk
                    MY15 TIGUAN 130TDI R-LINE - Pepper Grey, Panoramic Sunroof
                      19" should have the same rolling circumference as 18" wheels. Just the sidewalls are shorter. I think mine with factory 19's was reading 114km/h on the dash and 110km/h on the GPS. What you're describing doesn't sound right.
                      Sent from my Pixel XL using Tapatalk
                      OCTAVIA 3 PARTS FOR SALE:
                      Brushed stainless rear bumper & cargo protector, Octavia III Combi models
                        Speedos in AUS must comply with ADR rules which put simply say that they can read up to 10% + - 4 higher than actual speed at 100kph
                        They may NOT LEGALLY show LESS than actual speed. If yours is reading less than actual, someone has fitted wheels of a much larger overall diameter to do that.
                        Our Polo reads 7 over at 100kph and to correct it to show 100 at 100 would take a diameter of 46mm more which is illegal in Queensland
                        I suggest you take it back to where you got them and point this out.
                        We have not been able to adjust the speedo calibration on either car using VCDS
                        Here is the best comparator to find out
                        Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
                        Put the old size and the new one in and it will tell you how speedo will read Dont worry about offset it doesnt make any difference
                          Just to clarify the wheels were fitted to the car when sold new. The dealer had an RS buyer who didn't like the wheels so swapped them for the ones on a diesel style. Tyre size is 225/35 19, as per 19 inch black pack.
                            So what size and tyres were the ones they swapped off it
                              If you bought it like that, take it back to the dealer and get them to check it as it wouldn't pass as being a compliant car otherwise. As others said usually at 100km/hr the Skodas are usually 96km/hr or under. Mazdas are usually dead on 5km/hr under. Australian built cars are bang on the true speed.
