Why would the 2018 Owner manual SPECIFICALLY say not to use distilled water with the washer fluid? It says use clean clear water. Well you can't get any clearer or cleaner water than distilled, and as a chemist this beats me. Is a certain level of electrolytes required?
When using the windscreen washer system (pulling the lever), do your wiper blades grind across the dry screen once before the fluid gets to the glass?
