VRS 2007 issues with surging
  • VRS 2007 issues with surging
    Hi All,
    Have searched the site but thought i'd post up my problem as you maybe able to assist.
    I just got my 2007 VRS 2.0l petrol manual and have noticed in the last weeks or so that under accelaration there is a stutter or surge like feeling. I am new to turbo cars and have read about boost leaks and such but not sure if this surging / stutter in power is what it would feel like.
    Could it be plugs or coil packs?
    I am in South East Melbourne is there somewhere you would recommend i go to get them to check it out?
    Thanks in advance
    Danny
    Is the car standard ? Surging is usually associated with running lean, is the car running hot ?
    2014 MY14 Corrida Red Elegance Wagon TDI
    2009 MY10 Race Blue RS Wagon TSI 6 sp. manual. (Gone)
    2011 MY12 Yeti 77 TSI DSG.
      Stutter (hesitation) and surge (sudden power) are completely opposite - perhaps you could better describe what's happening?
      If you are in a high gear and nail the throttle to the floor there can be a pause/delay while the DSG makes the "unanticipated" gear change (1.1 seconds) - this can feel odd and you will get a significant surge of acceleration once it's in the right gear - you can avoid this by manually dropping down a few gears, then you are ready to go
        its completely stock, and a manual.
        The sensation is no power, but comes in blips through the rev range. Was fine when i bought it a month ago and now not so.
        I am only assuming boost leak on what i have read, but still not sure.
        Will likely take it to a mechanic to check it out, but was kinda hoping it was an easy diy fix
          Smoke test should pick up any leaks. I'd check the DV cause does the 2007 model have the older DV?
            Hmmm, a boost leak throws a CEL
            Coil pack failure (normally number 3) has a much more significant impact (very common on cars that have a performance ECU flash)
            How many km on the clock?
            Does it run rough on the first start of the day?
              I've got some coil packs handy if the 2.0 tsi (147) is the same as yours and you want to borrow to swap out for troubleshooting. I have the same issue in a 2012 vRS but it's a DSG and only problematic with a bluefin tune, and fine in S mode...
                Hi All,
                Thanks in advance
                Danny
                I take all my VAG cars to Auto Union Deutch in Oakleigh.
                2001 - A4 B6 1.8T Sedan Manual - (sold @ 254,000km)
                2008 - A3 8P 1.9tdi Sportback Manual - (sold 90,000kms)
                2013 - Octavia RS wagon - 1z - Race Blue - TDI - 6M - Leather - MDI - Whispbar S44W - LED interior kit - RVC forward?/retrofit - Mk3 gear shifter
                2021 - Q3 S-Line wagon - F3 - Daytona Grey - Westfalia towbar - no other options available.
                  Mines booked in at Volkservice Braeside for the first time in a few weeks. Will let you know how it goes. I've always heard good things about Auto Union Deutsche as well...
                    Thanks everyone, I have also booked in at Volkservice Braeside this Friday.
                    After reading Martin's post i think it could be coil packs, this is my first turbo so straight away thought boost leak but feels like coil packs to me.
                    How do i know if the ECU has been flashed? is there a way i can tell?
                    Will let you all know what they say at Volkservice
                    Danny
                      No, coil pack failure has much larger impact and symptoms, you would not be driving it around with coil pack failure.
                      (Flashing the ECU is done for more power - APR, Recode, etc)
                        I understand why the ECU is flashed, but is there a way to tell. Not having driven a GTI or VRS before i have no base line for performance.
                        Will see what the mechanic says, either way i hope its an easy fix
                          if somebody is driving behind you a black haze from the exhaust, especially during the gear change, is an indication of a tuned/flashed ECU
                          Otherwise, without a benchmark a stage 1 tune may not be obvious (a stage 2 tune is fairly obvious as it's rather aggressive)
                            Ok, so got it fixed.
                            It was cylinder 3 coil pack.
                            Drives great now. Andrew at Volkservice was very helpful and fast.
                            Thanks for all your help guys
                              Great to hear on both fronts. I swapped my coil packs for the red top ones, going to get some logging done but I suspect my tune doesn't play well with the DSG since it's fine in S mode and when shifting manually...
