Wheels. 19 inch vs 18 inch
  • Wheels. 19 inch vs 18 inch
    I have 18s on my Octavia wagon. I could have got 19s from new, indeed they were on the car at the dealers, but I thought the ride was very harsh with 19s. Now I am looking at some new wheels (VMR V701) in 19 inch and weighing up beauty vs utility. Bit like considering a new girlfriend! Ha ha.
    What are opinions on 19s vs 18s? Mine is a work vehicle, will do about 25,000 km a year, mix of suburban and interstate.
    What's the weight difference including tyres? Heavy rims/tyres on the front will give you more axle tramping.
      19s for looks (subjectively), 18s for ride, performance, price, ie everything else.
        Stick with 18s
        get either 7.5" or 8" but get a slightly more aggressive offset
        Buy something around 8kg.
          Fully agree!
          Also choice and price of tyres
          The 225/40/18 is a very common size where as 225/35/19 has less options and higher prices
          Then there is the higher risk of pot holes hitting your rim as a 35 profile is getting very skinny
            I have the 19" on mine, and while it looks good, I hit a fairly shallow pothole a couple of weeks after delivery and damaged two tyres. I think the 18" with the higher profile would've had a bit more compliance.
            .: MY15 Octavia vRS Wagon | 2.0T 162kw DSG | Moon White | Pano Roof | 19" Black Pack | Canton Audio + RVC :.
              If you run 19s then you have to increase pressures to compensate for the lack of free volume within the tyre carcass.
                18" tyres paid $690 for potenza s001 in 235 40 18 with 4 for 3 special.
                a friend paid $1200 for potenza re003 in 235 35 19 with the same 4 for 3 special.
                Sent from my GT-I9506 using Tapatalk
                MINI Cooper S Clubman - FWD
                  i'm just checking if this is in relation to the tyre question or the potential girlfriend question?
                  on a serious note i changed from 18's to 19's and noticed a massive difference in ride comfort. that said it's probably ok for 80% of the time so up to you if you are prepared to suffer a bit over poor road surfaces...
                    Yep, I'm running 38F 37R. The dealer always drops it down to 34/33 when it goes in for anything.. too low for 19's IMO.
                      i'd be running at 42F/38R in a 225/35r19 with just 1 or 2 people on board. Your dealer is insane.
                      just out of interest, what does it say inside the fuel flap? I'll assume 19" isn't listed but what about for 225/40r18?
                        My fuel cap sticker has all three (17", 18" and 19") sizes and pressures on it. Ill take a photo and post it.
                        MY15 VW Golf R | White | Manual
                        MY15 Skoda Octavia RS 162TSI | Liftback | Race Blue | DSG | Tech Pack (w/o RVC) | +2 Years Extended WarrantySOLD
                          Yeah I find anything below 38 too low. Sticker says 39/39. Most of the time it's just me and the 3 kids. Lots of road work going on around here though so I found 40+ a bit harsh.
