Heads up to those with a manual gearbox.
VW say it's a lifetime fill. Which it probably is if you class a gearbox life as the point where it breaks due to lack of good lubrication...
My car has 140,000 very easy km on it. Generally I'd change the gearbox oil around the 75k-100k mark so the lifetime fill gearbox oil was annoying me.
Drained it out (drain plug & the #2 selector fork(??) bolt)and the stuff was very black and a bit stinky (I assume it was mineral oil). Almost no filings on the magnetic sump plug.
The 1.8tsi has a different M6 gearbox to the vRS so it only needs 1.9L to refill (vRS is 2.4L I believe). This makes the oil level higher than the fill plug so you either need to refill on a steep slope or via the reverse switch hole.
I used the latter option. You need a lot of patience as it's a 10mm hole. The 10mm OD hose I had was 6mm ID. I'd lent my small funnel to my wife & she couldn't find it so I used a syringe with a large funnel jammed into it. 1.9L took about 2 hours I guess.
I couldn't be bothered going to VW to get the oil so i used Penrite 70w-75 Synthetic (Penrites recomended lubricant). 2.5Litres was $58 ($23.20/L) from the local Bursons Auto Parts. Genuine VW is probably similar money.
I've got ~600ml left if anyone wants it for $5 - then you just have to buy 2L if you have a vRS.
Gearchange is no different - maybe a fraction smoother but self-justification is a wonderful thing and I didn't have an issue before.
I appear to have improved my fuel economy by a small amount but I've had other issues with a fouled O2 sensor so maybe that is fixing itself as well.
