Originally posted by wai
View Post
When you look around the Octavia 3 there are a lot of little tweaks to improve aero.
Underneath there are small tab deflectors in front of the wheels front and back, the bottom is relatively smooth until you get to the large gap under the rear seat. The 'cavity' (200 litres?) is big and empty on mine because I have the torsion bar suspension but I assume it is provision for multi-link rear, 4WD, (or even batteries for future hybrids?). In front of the cavity is a plastic ramp with 'turbulance' fins to carry the air beyond the gap to the rear wheel well and further airflow smoothing plastic.
The engine air cooling (which accounts for 35% of drag) has been modified since my Octavia 2, on that car the radiators just sat at the front of the engine. Now on the Octavia 3 the air is ducted through the front vent to the radiator and has to pass through it, it cannot go around it. Behind the radiator there is one fan to suck air through when required which covers about 2/3 the surface area, the rest is covered by one-way flappy plastic pieces so that when moving forward they open naturally but when the car is stationary and the fan going then hot air has to vent underneath not back through what would be uncovered radiator.
On the body there are subtle curves and creases at the rear to cut off the attached airflow and reduce turbulence. There are better and more effective ways of doing this but they usually compromise looks or internal packaging.
Overall it is not a bad job and the manufacturers would not include all this stuff if it did not work, because most of it is not obvious.
