$198 while a premium price isn't OTT. It isn't hard for a set of pads to crack the $400 mark
What Ceramic pads would u recommended? - 2011 vRS
Looking for the occy mkII vRS brake pads and found this for the fronts
OCTAVIA VRS BRAKE PADS FRONT 2009-2013
And then this website seems to show the alternative manufacturer part numbers yeah?
3C0 698 151 C,VAG 3C0698151C Disc Brake Pad Set
Still searching for the rears.Last edited by donweather; 14-08-2014, 08:57 PM.
Is this them for the occy MkII vRS TSI? Both fronts and rears?
ATE 13046071842 Disc Brake PAD SET | eBay
I can fit the ATE Ceramic to those in Adelaide.Originally posted by warrick View Postare the ATE Pads available here in Australia? i see ebay has them available ex UK.
cheers
warrick
...and yes they're virtually dust free, no reduced dust as Remsa and others. You won't need a sponge for the wheels anymore if you're using a high pressure cleaner for washing your car.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
That's just an OEM pad. That won't achieve the reduced dust outcome you desire. Postage will kill it too if my previous enquiries on other parts are an indication.Originally posted by donweather View PostLooking for the occy mkII vRS brake pads and found this for the fronts
Still searching for the rears.That appears to be an OEM replacement & won't reduce dust. partno EU1107Originally posted by donweather View PostIs this them for the occy MkII vRS TSI? Both fronts and rears?
ATE Ceramic front is ELD1107 / LD7184 / 8212-D1107
Found these. Better to buy in AU by the looks of it.
Hawk & Acebono do ceramic at ECS tuning for <$200.carandimage The place where Off-Topic is On-Topic
just picked up the ATE Ceramic pads.excellent service.ordered yesterday arvo. now just got to wait till the end of the month till the DBA Slotted discs arrive at GSL Rallysport.
cheers
warricksigpic2011 3CC 3.6 V6. 19X8 CADWELL RIMS, K & N FILTER, EXHAUST TIPS,DBA SLOTTED FRONT DISCS,ATE CERAMIC FRONT PADS.
Hmmmm
I've heard a lot of negative comments about RDA rotors (including from workshops I trust)
Easy to get a wobble out them, especially after giving them a hiding
They are cheap and if that's your primary focus then that's fine
I regularly get rotors skimmed as I maintain 3 cars
2 of these cars have high friction pads that tend to eat into the rotor
It only costs me $50 to have two rotors skimmed
Ceramic pads, a lot of variable options
I put a set of ceramics in and was disappointed, high levels of brown dust
But they did settle down after ~3,000km - almost no dust at all now - happy (but no good for a track day)2012.1 Skoda Octavia VRS DSG Wagon - Carbonio cold air intake and pipe - HPA Motorsports BBK 355mm rotors 6 pot calipers
The ATE Ceramic keeps your wheels clean, other brands maybe just use the term "ceramic" and don't care much about the cleanliness of your wheels.
You're right about the RDA discs, they do distort, but even if you're replacing the discs yourself, at the moment you have to get them machined they become more expensive.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
i agree about the RDA Rotors which is why i'm getting the DBA. i've had a couple of sets of these on other cars with no problems.
cheers
