I'm needing to carry a sheet or two of form ply on the roof racks of my MY11 RS wagon fairly soon and I'm thinking that the radio antenna (the stubby, "rubber ducky" style) will get in the way.  I've tried unscrewing it from the shark fin base, but without much success.  Not wanting to applying brute force and ignorance, does anyone know the correct method for removing the antenna?
Radio antenna removal
 If you can unscrew it enough so that it's loose then you can fold it horizontal & tighten it back up in that position (simply clever style).
 If you want to remove it then you have to apply extreme amounts of force. I usually attack things with a 2kg ball pein hammer, 12" screwdriver & other tools of butchery & I've got to admit that total removal of the aerial was beyond me.carandimage The place where Off-Topic is On-Topic
 Hmmm thanks guys. Seems like I have a 50% chance of removing it! I'll have another crack at it and apply a little more muscle. Not a great piece of design, as it kind of limits what can be carried on the roof racks... MY 22 Superb Sportline Wagon. Moon White. MY 22 Superb Sportline Wagon. Moon White.
 1985 BMW K100RS in JPS racing livery
 2019 BMW R1250GS Exclusive
 Just went and had a go - screwed straight off. Give it another go!
 He would have the AM/FM/GPS antenna like mine.Originally posted by brad View PostCan you post an image because I get the feeling we are imagining different antennas.2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
 Not including hers...
 Originally posted by Mysticality View PostJust went and had a go - screwed straight off. Give it another go!
 Yep, same as yours - http://www.vwwatercooled.com/forums/...-34412-13.html
 I figured that it should probably just unscrew, but it wasn't doing so as easily as I expected. Now that I know it does unscrew, I can apply the appropriate amount of persuasion...
 I'll give it a go on the weekend.
 Thanks.MY 22 Superb Sportline Wagon. Moon White.
 I have Thule AeroBars on the RT757 foot packs on my Octy RS wagon. I solved this occassional problem with a Honda R type 65mm antenna. It's a straight swap, and change to the FM performance around town and surrounds is not at all noticeable. The original antenna now has a permanent home in the glove box. There are heaps of these available on eBay or Amazon, and they're like the birdies ...... cheap, cheap!
 Universal torque setting - strip thread then back off half a turn.Originally posted by brad View PostIf you want to remove it then you have to apply extreme amounts of force. I usually attack things with a 2kg ball pein hammer, 12" screwdriver & other tools of butchery ...
 Multigrips - Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
 Vise grips - Generally used after multigrips to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
 2T trolley hoist - A tool for testing the maximum tensile strength of all the crap you forgot to disconnect.
 Hacksaw - One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
 Hammers - Originally designed as weapons of war, the hammer nowadays is used as a divining rod to locate the most expensive parts adjacent to the object we are trying to hit.
 And remember the Golden Rule - If you think you need a bigger hammer you undoubtedly do.
