Oil Change & Lifting Points
    You would have to be pretty stupid to flatten your sill panels if you use your whatever jack you have, as long as you protect it by placing a wooden or rubber block between the jack and the sill panel. I use 2 trolley jacks when jacking the cars up and in 20 years in business I can tell you that it takes more than 10 years before the car body (any brand) gets weak and the sill panel is unreliable for jacking up.
    Certainly I'm yet to see 1-10 years VAG car with the sill panels that aren't fit for jacking up.
    You're worried about the problem that doesn't exist yet.
      don't drive under severe driving conditions
      ^^^^this is the important one.
