I flattened the battery the other day due to an issue with the front parking lights - I'll address that once I've sorted this.
Battery was at 10v (according to VCDS) when I tried to start the car. After recharging the battery the steering wheel & ESP warning lights were on.
Drove the car & the steering felt normal. Both warning lights disappeared but the Check engine light came on.
Cleared the CEL & the steering & ESP lights re-appeared.
Checked in the Ross tech infobase & did a Sensor for Steering Angle (G85) basic setting & a Steering Limit Stop Adaptation & cleared the fault codes. VW Golf (1K) Steering Assist - Ross-Tech Wiki
The steering wheel & ESP warning lights are gone but now the steering is very heavy at low speeds & doesn't return to centre at all - you have to steer it all the time. It's like driving a '70s Bedford truck. It is beautifully weighted at 80kph+ though.
Could it be that it's "lost" the characteristic curve?
Thought I should ask here & try & get a logical plan of attack for diagnosis & repair rather than blindly proceed.
PS: would I be better posting this in the VCDS section?
