Buy a used Octavia.
  • #16
    If the price is right & the rest of the car looks genuine - in a heart beat. I'd have no issues buying another Skoda.
    • #17
      My two bob's worth. If tyre noise from the front is the only issue and the car looks straight, with no obvious collision damage, it's hard to imagine you'd be up for any expense beyond tyres and wheel alignment, which is minimal in terms of your purchase price. Noise sounds a lot like directionals fitted backwards (tyre rotation across instead of Fr to Rr?). Once you own an Octavia you'll wonder why there aren't thousands more on the road.
      Had our 4x4 Octavia Scout (TDI 6-sp manual) for over a year now, bought with 47k and 2 years old, and still think it's the best car I've ever driven, let alone owned! The manual is a treat too.
      • #18
        Because VW Australia don't want them to be, they want VWs to be the bulk car and Skodas to be niche and are scared that wherever Skoda gets a foothold, eg UK & Germany they outsell everything else. I'm sure plenty of VW dealers were very nervous and were probably pandered to keep Skoda low profile (likely still are).
        • #19
          Originally posted by MYSKODA View Post
          Much appreciated for the info Brad. So all in all, would you buy it?
          YES
          i've got a 90tsi wagon, and the only thing that I have a problem with is the DSG. that car is a manual so it'll be even better.
          got enough power on the daily drive, and very good economy (for a suburb-driven car)
          also, ridiculous amount of boot space.
          good luck with the purchase!
          2012 Yeti 77TSI, Candy White
          ydad.com.au: musings of a dad growing up - the blog.
          cbay.com.au: photography, video, design - creations.
          • #20
            One thing to look for is about 10mm play in the steering wheel. Caused by looseness in the shaft at the bottom of the steering column. Only official fix is a new column at $960 plus fitting! I had this on a 67,000km car.
            2008 Skoda Octavia Elegance TDI 4x4 wagon
            Bluefin 132Kw/385Nm, Racechips Response Control, Haldex Performance controller, H&R anti roll bars, Koni FSD shocks, SuperPro control arms & ball joints, subframe & gearshift mods, Full Dynamat interior, Polk Audio sound, Columbus, Bluetooth, MDI, parking sensors, camera. BBS SR 18x8" w/ 225/40xR18. 3M Crystalline tint.
            • #21
              If that is the case, loose shaft, the car still has over 6 months warranty. Id like to think that would be covered. Thanks for the heads up ill check it out.
              SKODA OCTAVIA MY10 SEDAN. WHITE 118TSI, 7SPD DSG.
              • #22
                That's seriously low mileage to present a problemo like that, wfd. And 7k out of warranty too? Any clues as to the cause? Bad case hardening on the rack or pinion?
                • #23
                  Theres a polymer bushing in the shaft that has a known early life failure on some units. Its not very common but its been documented elsewhere.
                  must have been the production run of one set of bushings.
                  '98 Mk3 Cabriolet 2.0 8V
                  '99 A4 Quattro 1.8T
