Scout starting to use more diesel
  • Scout starting to use more diesel
    Hey
    I was wondering if anyone had experienced increasing fuel consumption out of the Skoda diesels?
    Mine (scout) used to do 5.3l/100k all the time from home to work.. now its 5.7 to 5.9 l/100 I have a patient who has a diesel octavia and he remarked his is now thirstierand for no apparent reason
    What gives?
    For the record car bought April 2012 53000 country k's on clock, serviced at specified intervals
    Thanks
    In Albury you wil be currently using winter diesel I would think. Winter diesel will get worse economy than summer diesel.
    My Škoda photos here
    Flickr : Blog
      Noa that makes sense
      Thanks for a completely believable reason. They put more parrafin in? I was beginning to think I had some dreaded VW defect. Not that i have lost my faith in the product......
      Thanks again
      Nick
        Thanks again
        Nick
        They dilute it with heating oil to lower the 'cloud points' so that wax crystals don't form and clog the fuel system. Some good info here -http://www.caltex.com.au/sites/Calte...esel%20FAQ.pdf
        I've just done a trip to Falls and filled with Alpine mix at Mt Beauty but didn't notice a great deal of difference in the economy. I got 7L/100km over 540km with a fully loaded car on the Alpine mix which is about .2 more than normal on Vortex.
        Indium Grey Golf 7.5 Alltrack 135tdi Premium - all options
          How do you calculate the fuel economy? From the docket or you go by the trip computer?
          I don't have a trip computer in MY05 T5 that I drive everyday the same trips and under the same conditions. To get my fuel gauge from full to 1/2 the tank it takes 420-450km as from the day 1 when I've bought it 8.5 years ago. But when I calculate the fuel economy from the docket I get 1.5L-2L worst economy than back in 2005 or 2006. It seems to me that more expensive fuel gets, less goes in the vehicle tank from the pump at the fuel station. Or maybe the fuel tank in my van has stretched over the years. Certainly you wouldn't think that they cheat on us and set these pumps to use the US gallons instead the Litres, because the difference between the 2 measures is 50mL and when I calculate with that I get spot on fuel economy like back 8 years ago. But then, they confuse me again because some fuel stations are still quite accurate, so I stick with them.
          Edit: it's a good practice to keep all the fuel dockets, just in case that you get contaminated fuel to kill your DPF, fuel system or the engine, because the contaminated fuel is not covered by any car manufacturer's warranty and you will have to chase the fuel company for compensations. Oh and also, photocopy those (some) dodgy fuel dockets, because, they fade even hidden in the filing cabinets within 6 months, yet nobody is forcing the retailers to change their docket printers.
            So what are you saying?
            I buy dirty fuel today and it takes 6 months before it damages my engine? Hardly.
            Flickr : Blog
              For recording fuel I use a great iPhone App called AccuFuel. There are plenty of apps but I have been using this one since before I had the Skoda and it works so I stick with it.
              I put in the actual litres put into the tank, the odometer reading and the price and the rest is worked out automatically. Results can be exported as a .CSV file if you really want to play in Excel. I can see on the phone screen a little graph that shows all the way back to when I purchased the Skoda with peaks and troughs that relate to holidays away (reduced consumption) and lots of city driving periods (higher consumption).
              I highly recommend the app if you want to keep records of fuel consumption.
              Flickr : Blog
                I keep all dockets as I need them for my car allowance, tax return stuff and the fading ones drive me nuts. I swear in some stations the cost counter starts winding around long before any fuel is coming at the beginning and I do often wonder in recent times whether they are measuring accurately. In my old job I had access to all kinds of measuring cylinders, if I was still there I would love to test some pumps out at times. It doesn't fill me with confidence that my usual suss diesel pump is quite often our of order and not because the tank is empty.
                  You do what you like mate, I would never dare to give you any advice.
                    The basic premise that you should keep records is a good one and good advice but the reality is that unless you have suspect fuel in the tank of your vehicle when it breaks down you will have zero percent chance of making a successful claim against a fuel company.
                    The other suggestion in this thread is that there are instances of dodgy calibration of fuel pumps. By law in Australia fuel pumps must be accurate to +/- 0.3% (300 ml over 100 litres or about +/- 50 cents variance over 100 litres at todays prices) and all pumps should have a sticker or other marking to indicate when they were last checked and calibrated. The reason pumps appear to move quickly at the start of pumping is that pumps dispense a minimum these days of 2 litres in most cases so some pumps will race up to two litres then start counting properly once 2 litres has been dispensed.
                    Flickr : Blog
                      Re: Scout starting to use more diesel
                      The dpf will not block overnight, the hpfp will not wear out within 1 or 2 weeks, so yes it can take some time before the damage shows up.
                      I buy all my fuel from BP and usually stick with one servo.
                      Sent from my GT-I9505
                        Hey
                        What gives?
                        Thanks
                        I have a 2010 Scout with 80,000k on it and noticed the very same thing! It seemed to happen during the coldest part of winter. I went on a long run and it seemed to correct itself. I thought it might have been the DPF as it ran roughly early one morning but then its been alright ever since. Back to normal now. So, although I have no explanation you're not the only one so its probably not your car! Here's Briskoda thread about the same thing. Appears to be a winter phenomenon may well be the diesel formulation.
                        MY2014 Skoda Octavia Ambition Plus Wagon, DSG, Capuccino, Tech Pack
                        MY 2010 Skoda Scout Manual Silver -traded
                          Cold air is more dense, maybe the sensors add more fuel to adjust the stoichiometric ratio.
                          2014 MY14 Corrida Red Elegance Wagon TDI
                          2009 MY10 Race Blue RS Wagon TSI 6 sp. manual. (Gone)
                          2011 MY12 Yeti 77 TSI DSG.
                            I expected they probably have tight tolerances, I probably should just use the other diesel pump at my usual place, as that one I have noticed odd things on as I mentioned quite often is out of action at times, probably as people notice it out of whack. I've never noticed the other one doing it and in hindsight it would make sense. Mind you a very legit and schmick BP that is new just down the road stole my card details and sold them off to some dodgy buggers a few years back. Turned out they were one of the stations with late night attendents getting paid 60k or so by asian gang members to install hidden cams and card skimmers. Thankfully I got the money reversed.
                              ...and I thought that there are only honest people in today's world?
                              Glad that you weren't out of pocket for too long.
