I'm ordering spacers for the rears (20mm) anyone using them at the moment?
Wheel Hub Spacers - anyone use them?
No, they are illegal to use on road registered vehicles unless supplied by factory.
Also i have heard of some of the cheaper ones fracturing.
yep.. illegal...even tho ive seen some cars with them on..told the customer and they didnt know.. when the rims were fitted at a proper shop they put them on!!VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
I'm considering getting 10mm spacers... especially for the rears on mine.
I know about the legalities, but for 5-10mm? Really?... My cars a bit of a legal anomally anyway2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
Not including hers...
Originally posted by Mysticality View PostI'm considering getting 10mm spacers... especially for the rears on mine.
I know about the legalities, but for 5-10mm? Really?... My cars a bit of a legal anomally anyway2021 Kamiq LE 110 , Moon White, BV cameras F & B
Yes, they're illegal in Australia. (What isn't these days?)
If they're TUV (etc) approved, I wouldn't bat an eye lid.
Just make sure you use longer bolts, and as mentioned before, don't get cheapies.
Originally posted by Hillbilly View PostFar better to get wider rims or a wider profile tyre and be safe 10mm is hardly worth while anyway
For the cost of a set of 4 quality spacers you could just get a better set of wheels that actually fit with the correct width and offset without the legal issues.
I'm sorry what?
What set of wheels could you get for the price of 4 spacers? I think you've made a bit of a mistake there.
Originally posted by Hillbilly View PostFar better to get wider rims or a wider profile tyre and be safe 10mm is hardly worth while anyway2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
Originally posted by boogz View PostI'm ordering spacers for the rears (20mm) anyone using them at the moment?
Yes, they were/are illegal. So is speeding, running HIDs without washers/auto-level, etc.
On a Skoda, you can get away with ~7mm (maybe 10mm) spacer & still use the original bolts with sufficient thread engagement.
A pair of 10mm hubcentric spacers with new bolts will be about $150 off ebay
Mysticality. It's got nothing to do with wheel or tyre size. More about the rim offset. Maybe you should have got ET35 (sounds like you are on ET45)Last edited by brad; 06-06-2013, 06:16 PM.carandimage The place where Off-Topic is On-Topic
Originally posted by Diesel_vert View PostIn case you are unaware, fitting a 235/40 R18 tyre on a 7.5 J x 18 wheel renders the vehicle unroadworthy.carandimage The place where Off-Topic is On-Topic
5 or 10 mm might not seem much but the steering offset is generally +/- 25 mm (depending on whether you have a negative or positive offset. A 10 mm spacer can easily change that offset significantly and change the way it responds to steering input. You don't have steering offset issues on the rear, but you do have increased bending loads on studs/bolts.
This is much like what Ford Escort and Capri owners would do to their cars. They used to use longer spring shackles for the rear leaf springs so that it gave the car a "nose down" appearance. It did that, but also took all the caster out of the steering. Not a problem at city driving speeds, but on the open highway, the car would be extremely unstable.
If you want a wider track, then the way to do it is with wheels that have the appropriate offset.
I think its way too much of a generalisation to say spacers are dangerous. Spacers are not dangerous - but some spacers are cheaply made and may crack, and if you use spacers with incorrect bolts well you are asking for trouble.
People have been using spacers on the race track for eons, (where the loads are far higher than on the road) and some manufacturers have used crazy spacers (I'm looking at you Porsche!!!) on factory cars aswell.
As far as the engineering goes, a properly fitting spacer with appropriately long bolts is just as safe as anything else. (Trust me, Im a gingerbeer.... i mean engineer).
But yes its still illegal unless engineered.'07 Touareg V6 TDI with air suspension
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
Originally posted by brad View PostIndeed it does. Would look very baggy. At least they wouldn't have had any issues getting the bead to seal
Doesn't look strange, at all.
I thought it would, but nope...2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
