Good advice Martin on checking price..... I just stockpiled some 215/35r19 Pirelli pzero Nero assimetricos for 165 ea! Cheap as..... I paid more for my kuhmo's!
19" wheels. Any probelms fitting them? Need any modifications?
Thanks Martin!Originally posted by Martin View PostTo be clear, you will be running 225/35/19 tyres (check the price...)
You will be running same overall size and offset as me - and I'm already lowered 20mm - works great
Yep I am going the Continentals...and they will be 225 /35 /19.
Getting the springs done today, and wheels tomorrow...
Cant wait!... I feel like an excited kid in a fun park!...("Which ride do I go on first??, "I want an icecream etcc")2018 Ralyee Green RS wagon. Fully optioned.
Previous vehicles:2015 Volvo V60 Polestar (my one detour from VW/Skoda!)
2013 Platin grey RS wagon / 2012 White Polo GTI / 2009 Black 125 Tiguan
I think you've got it all back-to-front. ET35 gives more outward poke than ET45.Originally posted by Martin View PostTigger - the rear is more of a problem than the front
The Golf GTI guys run 19/8.5 ET35 - they pull the wheel into the strut for two reasons
To avoid rubbing (they have less clearance than us and normally run the car lower than us)
For suspension geometry - any 8.5" wide rim with a ET45 offset has added one inch all on the outside of the wheel - not good
If you are going to run 8.5" wide rims I think it's best to use an ET35 offsetcarandimage The place where Off-Topic is On-Topic
Indeed - this confusion has already been resolved below...Originally posted by brad View PostI think you've got it all back-to-front. ET35 gives more outward poke than ET45.2012.1 Skoda Octavia VRS DSG Wagon - Carbonio cold air intake and pipe - HPA Motorsports BBK 355mm rotors 6 pot calipers
You'll love the springs, no question about thatOriginally posted by Tigger View PostThanks Martin!
I will be interested to hear about your experience and opinion of running 19" 35 profile tyres!2012.1 Skoda Octavia VRS DSG Wagon - Carbonio cold air intake and pipe - HPA Motorsports BBK 355mm rotors 6 pot calipers
excitement!! are they the wheels from st george tyres i recommended?Originally posted by Tigger View PostThanks Martin!
2012 Yeti 77TSI, Candy White
ydad.com.au: musings of a dad growing up - the blog.
cbay.com.au: photography, video, design - creations.
Bad habit of mine - I read until I want to comment & don't bother looking further to see if the issue has been addressedOriginally posted by Martin View PostIndeed - this confusion has already been resolved below...carandimage The place where Off-Topic is On-Topic
OK, so the springs are on...and I gotta say....when I picked up the car, it didnt look any lower at all!Originally posted by Martin View PostYou'll love the springs, no question about that
So, I guess they have to settle in?? Well, I drove 40 kms, and they still dont look any lower...
Hmmm...so when I ordered them, I said "I have an RS wagon etc...I need lower springs..."
Do ya reckon I have just got another set of std RS springs?2018 Ralyee Green RS wagon. Fully optioned.
don't forget its only a 20mm.Originally posted by Tigger View PostOK, so the springs are on...and I gotta say....when I picked up the car, it didnt look any lower at all!
i measured (ground to top of wheel arch) mine before i had the springs put in.
the front dropped 30mm (from 680mm to 650mm), while the rear dropped 20mm (from 690mm to 670mm).
the rear "looks the same", as opposed to the front.Last edited by dArK5HaD0w; 26-02-2013, 07:01 PM.MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
Hey Tigger!
Did it feel any different to drive? The 1st thing i noticed was how much the rear squatting & front-end lifting was reduced, which was what i was wanting. My Tiggy did look lower, but not as noticeable as i imagined. Maybe you were expecting more?Current: MY18 TRANSPORTER CrewVan, Indium Grey
It never occurred to me to check that - I didn't get the springs to go lower, wanted the firmnessOriginally posted by Tigger View PostOK, so the springs are on...and I gotta say....when I picked up the car, it didnt look any lower at all!
(the suspension geometry works best around or just below stock ride height)
So I've now checked my before and after photos - it's not very noticeable at all!
How about the ride, is it firmer? Mine was very noticeable...2012.1 Skoda Octavia VRS DSG Wagon - Carbonio cold air intake and pipe - HPA Motorsports BBK 355mm rotors 6 pot calipers
Yep...I'm not complaining.
It certainly drives MUCH better!
The turn-in is so much sharper, and the reduction in body roll is amazing!
I would not have thought springs could make that much difference. It feels more Golf R like in its drive / feel...
I am really glad I have gone down this path!
Tomorrow is new wheels and tyres time!
Yay!2018 Ralyee Green RS wagon. Fully optioned.
Eibach vRS deisel wagon springs dropped my 1.8TSI sedan 30mm at the front & zero at the rear.
It's brilliant, the higher back end gives better turn-in & if I want to be a nob I can get the back end to hang out. Less pitch, less body roll. The back end doesn't sag if I have a full tank of fuel & 20 bags of mulch in the back.
Not sure if this will be a totally good setup for when my daughter starts driving it (eek!).
It needs new dampers & I'm tossing up between Konis or coilovers - there isn't a lot of difference in the pricecarandimage The place where Off-Topic is On-Topic
That would reduce the caster angle - very slightly2012.1 Skoda Octavia VRS DSG Wagon - Carbonio cold air intake and pipe - HPA Motorsports BBK 355mm rotors 6 pot calipers
among other (very slight) things. Used to do it on the motorbikes as well.Originally posted by Martin View PostThat would reduce the caster angle - very slightly
Octavias are running ~8 degrees IIRC. I remember people thought I was a bit radical setting cars up with 4 degrees when the specs were 1-2.carandimage The place where Off-Topic is On-Topic
