Temp of Oil as shown on the MFD
  • #16
    you mean so you can drive home in your own car no matter what happens on the track??
    my mate has a 206 GTi 180, goes very well! how did yours go on the track?
    • #17
      Think I did a low 1.15 in the R32 and about 1.18 in the 205. Both probably had an extra second in them if I had a bit more practice.
      2010 Skoda Octavia vRS Wagon
      • #18
        Originally posted by Tigger View Post
        So is there a place / track where we can just roll up or book in to use it?
        Do we have to be members of a club or something??
        There are several ways to do it
        Eastern Creek (MotorSport Park now) has self drive days $360
        Or you go on a CAMS car club sprint day
        You learn a lot and it's great fun for sure
        Originally posted by sir_camel View Post
        Driving on a track in someone else's car is FAR better fun than in your own though I imagine!
        Yes and no!
        You get to drive equipment you can't afford or are not allowed to purchase
        At Eastern Creek I once arrived at the end of the main straight doing 240kmph in a BMW M3
        It had started to very lightly rain - the track looked fine to me and the lead driver did not back off
        However, when I turned in the stability control kicked in, I could feel the ABS stabbing at the wheels
        the car simply tightened it's line, it was a wonderful safety demonstration by the car
        Given the car cost $150K I just let the stability control manage the situation
        • #19
          Originally posted by K1W1 View Post
          All you have to be concerned about is making sure that the oil has circulated through all the galleries and tubes. That takes about 30 seconds after that you are waiting for everything to get to correct operating temp for maximum efficiency but you won't do any oil related damage.
          Sounds like an ideal way to spin a bearing. Metals expand at different rates so you need to achieve NOT before getting stuck in. If the crankshaft has expanded quicker than the crank bearings there won't be enough clearance for a boundary layer & threfore damage will result (that is oil related)
          • #20
            I've only driven mine in Summer (had it since mid December) but I've noticed my oil temp nearly always between 100-105 deg C just general highway cruising.
            My previous car (xr5) only ran over 100 deg C a couple of times that I remember. Octavia seems to run hotter or it's reading temp from a different position. Anyone know where the sensor is and if they have a standard oil cooler (TSI)?
            • #21
              I wonder what temp would be too high...
              Most modern cars that I've seen with oil temperature gauges allow the oil temperature to reach 140-150°C before the vehicle warns you of a high oil temperature.
              We know there's no inherent danger in revving the engine, or even cruising at, very high RPMs as it's part of the design brief - so long as you don't go beyond the redline.
              Similarly, there is no inherent danger in allowing oil temperatures to reach very high because it's part of the design brief (for both the engine and the oil) - so long as you don't exceed the temperature warning threshold or skimp on oil.
              Obviously, if the engine is likely to experience high oil temperatures for an extended period of time (frequent towing, track days, racing, etc) then it would be smart to deal with that by fitting axillary oil coolers and such.
              However, in the same way that keeping the engine revs down would aid in its longevity, so will keeping the oil temperature down (but not too low, as you want it to be hot enough to deal with moisture, fuel dilution, etc - short trips are much more likely to kill the engine rather than high oil temps).
              ... and worth being concerned about?
              Not unless something is malfunctioning on the engine.
              Storm in a teacup.
              • #22
                modern engines run much higher than 'older' ones. my last few cars have had water temps 90-100 and oil temps around the same. except when I give it the boot
                • #23
                  The Water temp gauge on the dashboard is very quick to act... When the water temp is 90 and the oil temp is 50, the actual water temp is around 70^C.
                  The highest oil temp I've seen my diesel cruise at is 105, the lowest cruise (more than 10min) is 89. Highest I've ever seen it at is 112, but that was after some extreme driving up a huge hill.
                  I have water temps from 89-94^C. (OBD-II scanner)
                  Usually the water is at 89 and the oil is at 94-100.
                  Not including hers...
                  • #24
                    Agreed, modern engines are putting out a lot more power per litre which results in a lot more heat
                    After a journey on a hot day you can pop the bonnet and find it's unconfortable to leave your hand on the shock tower
                    The water should stay around 90 - can't have it reaching 100
                    • #25
                      of course you can have it over 100. the system is under pressure so its not going to boil. also additives will help prevent boiling.
                      ive had my old car up to 118, but turns out there was a leak.
                      hotter engines means cleaner burns and less emissions.......
                      • #26
                        For every 10kPa of pressurisation it raises the boiling temp of water by 2c? Typical pressurisation is ~120kPa?
                        With the correct ratio of coolant the boiling point would be ~130c?
                        This is why a radiator that doesn't appear to be boiling/overheated send out a huge geyser if you are silly enough to remove the cap when hot - release of pressure which then causes the water to boil
                        • #27
                          Interesting guys - makes sense
                          I've never encountered high water temperatures
                          Last week it was 45 degrees on Tuesday, my water temp was steady on ~92 deg
                          • #28
                            put the AC, load the car up with the family and all associated crap and go sit in traffic
                            • #29
                              Minus family, plus gear in the back seat and thats what I was doing.
                              Must be when I hit 94.
                              It would seem that the Octy has an amazing amount of cooling power, but hardly uses any of it.
                              • #30
                                probably because its engineered to work from -20 - +50 without issues
                                I think there is a large volume of coolant in the system, and oil also.
