Just spoke to VW Australia and was advised (oil consumption)
  • Just spoke to VW Australia and was advised (oil consumption)
    That with my 2012 RS Petrol Octavia I should expect it to burn 1 litre of oil per 1000 km... That seems crazy to me. They also told me to expect that kind of consumption for the life of the vehicle.
    Does anyone have any info on the above? As that is way too high for my liking.
    So far I've used about 1.6 litres over 7800 km since brand new in 6 months.
    It's just luck of the draw I'm afraid...
    My RS has never used a drop of oil in 30,000km but some people on here report theirs using quite a bit. Not much you can do about it, except carry some oil with you and think it could be worse; you could own a RX-8!
    MY11 Octavia RS 2.0lt TSI DSG Liftback - Candy White
      Mine dropped to the low mark on the dipstick by 5000 km, when i changed the oil myself anyway. Had the 12 monthly service recently in brisbane and it's now clocked up about 13000 km after a trip from mount isa to coffs harbour and back (with the service in the middle), but i haven't checked the oil level since.
        mines needed about 1L each 5000km. as mentioned, its luck of the draw!
        however, the oil low warning is very sensitive, so youre not going to run out. that said, continue to check it!
          I believe that what VW are saying is that they won't consider the engine has a problem that they will address unless it is using more than 1 litre per 1000 km.
          This does not mean that it is OK, just that if you want them to fix it, they won't...unless directed to by some tribunal or consumer body.
            1L per 5000kms is perfectly normal and no cause for alarm for one of these cars. Most tend to do it.
            FOLLOW US ON FACEBOOK
              I came from Japanese cars that barely used any oil, if at all!
              I was shocked also, but its something with European cars. my fiat does it too. doesn't use as much, but its more than I considered 'normal'
                One thing to note is that after the initial 15k service you should see oil consumption drop. Mine was about 500ml in the first 15k, then dropped down to hardly anything. My Mazda 6 used not a drop. My wife now drives the Skoda in more shorter trips and oil consumption has crept back up a bit. The length of trips plays a big part in how much it will use as well.
                  if it doesn't get up to temp, it will probably burn it. I was almost putting so much oil in the fiat that I could probably have just changed the filter each year instead of dropping the oil too
                    I never have to top up oil between 15k services, whereas some Polo GTI's (same engine) are gulping the stuff down
                    Audi A3
                      I think it's a bit pathetic really. My dad's 1.4 litre golf doesn't use any oil, and neither does my 15 year old mitsubishi magna station wagon. If it's within spec to burn 1 litre of oil per 1000 km there is something wrong with the design of the engine.
                        My 2012 RS petrol has hardly used a drop. (Now 11,500kms since sept 30th)
                        My wife's 2012 polo GTI has hardly used a drop..(now 18,000 kms since June).
                        2018 Ralyee Green RS wagon. Fully optioned.
                          We have owned a German car of one sort or another continuously since 1982 and I would say our average based on well over 500,000km in them would be under to 0.5 L/1000 km.
                          Probably in the 1980's usage would close to 1 L/1000 Km in the days of less efficient oil and less precise manufacturing tolerances but now usage is minimal. The S3 usually has the light come on not long before each 15,000 km service so it gets 1 litre to last through to the service and my vRS (Diesel) has never had oil between services.
                          My Škoda photos here
                          Flickr : Blog
                            I check mine regularly (once a month) and have never needed to top up the oil.
                            i'm sitting on 42,000kms now
                              My oil light came on after 9000kms. Just took it to the dealers and they topped it up - for free.
                              I remember them saying when I picked up the car that I might need a top up before the first service and they'd be happy to top it up.
