A little bit OT but seeing as the conversation has drifted. The auto dimming interior mirror does not work if you have a tinted rear window.
Does anybody know how Skoda auto headlights really work?
I think mine still dims, but I have the premium with the so called privacy glass, not even as dark as the legal tint on my two front windows, LOL...---------------
MY12 Skoda Octavia Scout Premium 103TDI DSG Anthracite Grey
AUDIO Upgrade: Apline INE-Z928E, Focal amp/sub/speakers
That's right it doesn't need to work. I drove my car for a couple of weeks before I had the windows tinted and it worked fine then after they were tinted I noticed that it no longer worked (which is fairly logical when you think about it), tested to make sure that it no longer worked because of the tint by parking our other car behind mine and getting its lights turned off and on with the hatch of my car closed and open and then turned it off and have never thought about it again since until it was mentioned earlier in the thread.Originally posted by zei20t View Postdoes it need to work? the tinting probably does a good enough job if the mirror isn't dimming.Last edited by K1W1; 20-11-2012, 04:59 PM.
could always just turn the switch manually to what you want.....
If I'm going to pay money for a puppy I'm not going to start barking.Originally posted by Stan View Postcould always just turn the switch manually to what you want.....
Sure I can turn the lights on and off just like the old days but times have changed after all this car even has a radio and windows that go up and down both of which were missing from the first car I owned.
Did some tests just to confirm the obvious.
Headlights switched to auto and on, cornering lamps activated. Vehicle running but stationery.
Put the indicator on and the front fog lamp for the appropriate side lights up.
Turn the steering wheel and the front fog lamp for the appropriate side lights up. As far as the turning the wheel is concerned it's very sensitive you only have to move the steering wheel a couple of degrees and the fog lamp illuminates.
Same thing happens when the lights are manually switched on rather than in auto mode.
So strictly speaking it's probably illegal in Victoria because your fog light is on during periods when it's not required. I know it's only a technical issue and that nobody will ever get pinged for it but I guess its something to be aware of if you are sitting at a traffic light with a cop in a bad mood facing you.
I still haven't figured out how to get both fogs to light up and I have definitely seen that on a couple of occasions.
In my Tiguan, I had a starnge situation once where a bug just happened to get squashed right on the screen over the wiper sensor part...so it made the wipers act erraticallly...Originally posted by K1W1 View PostI pulled up behind a car on the way to work this morning (auto headlights on) and noticed that I had headlights plus LEDs plus fog lights on so as it was a completely clear blue sky with perfect visibility I manually turned the light switch off.
As I was nearing work I turned the switch back to auto and the lights came back on but a quick check in the front windows of the office showed that it was headlights only plus LEDs(not fogs).
I have had situation sin the past where I have noticed that the fogs and headlights have been on but most of the time it's only headlights.
How do these things decide whether to work and what lights to turn on?
And if your etag is too close to the back of the rear view mirror part that has the small sensor on it for the auto lights, it may affect the degree of light going in, and thus cause the lights to turn on....2018 Ralyee Green RS wagon. Fully optioned.
Previous vehicles:2015 Volvo V60 Polestar (my one detour from VW/Skoda!)
2013 Platin grey RS wagon / 2012 White Polo GTI / 2009 Black 125 Tiguan
Originally posted by Tigger View PostAnd if your etag is too close to the back of the rear view mirror part that has the small sensor on it for the auto lights, it may affect the degree of light going in, and thus cause the lights to turn on....
With current Octavias etags can go in the pocket on top of the dash and they work fine. No need to stick them on the window at all. Unfortunately the photos so far appear to show no dash top pocket on the new model.
That sensor is for the auto dipping rear vision mirror. I thought the auto headlights sensor was on the dash in between the windscreen defogger ventsOriginally posted by Tigger View PostIn my Tiguan, I had a starnge situation once where a bug just happened to get squashed right on the screen over the wiper sensor part...so it made the wipers act erraticallly...
And if your etag is too close to the back of the rear view mirror part that has the small sensor on it for the auto lights, it may affect the degree of light going in, and thus cause the lights to turn on....My11 Octavia VRS Tsi
Rockford splits in front - Tinted Windows - Viezu Perfomance tune - K&N Panel filter
The automatic lighting system works on ambient light sensed by the rain sensor in the mounting foot of the rear view mirror.
Automatic headlights activate the Low Beam (Halogen or HID), dim the LED DRL/Parkers, activate the rear parkers and never operate the fog lights. (Unless cornering fog lights have been activated in VCDS, but I'll get to that)
When entering a tunnel, the ambient light sensor will detect low light and immediately turn the headlights on.
When exiting the tunnel the light sensor will detect the bright light of day, wait for approximately five seconds and then turn the lights off again - just in case you're between tunnels, or there's a street lamp it thinks is daylight, etc.
The automatic headlights are also triggered by the rain sensor. If it rains enough for your wipers to be relatively active (I'm unsure of the frequency required, but its around the Intermittant setting on cars before variable intermittant wipers) the low beam headlights will come on.
LED DRL's operate as normal, at all times.
If the ambient light sensor or the rain sensor has triggered the headlights to become active, the cornering fog lights will in turn also become active - even if its bright daylight and its raining a little.
Cornering fog lights are activated when the steering wheel is at a 90^ angle from its "home" (straight in front) position.
Cornering fog lights are also activated when the indicators have been selected on either side of the vehicle, when travelling at 40km/h or less.
If you have the indicators activated on the right hand side, but the steering wheel is pointing to the left at more than a 90^ angle, you will have both fog lights on.
I don't know about anyone else, but my automatic lighting system gets stuck ON sometimes.
Example - I reverse out of my garage (dark) and into the daylight (bright) and the lights stay on. They then stay on for a further 5-10km until I park the car, turn the engine off and then restart it. Probably a bug - only happens once in a blue moon.
It has NEVER been stuck OFF... Which is always a good thing.
Not including hers...
The cornering light function activates at nearer 5 degrees off centre for the steering wheel. You only have to turn the wheel a small amount in either direction to get the cornering lights (fogs) to illuminate.Originally posted by Mysticality View PostCornering fog lights are activated when the steering wheel is at a 90^ angle from its "home" (straight in front) position.
