For those of you wondering about fitting different springs to their Octavia....
I have a 118tsi M6 sedan. I fitted a set of Eibach springs designed for a Vrs Diesel wagon. Generally, the Eibachs on a Vrs will give an additional 25mm drop on the Vrs which is already 25mm lower than the shopping trolley sedan that I drive.
As expected, the lighter weight of the 1.8tsi engine over the 2L diesel resulted in a drop in the front of 30mm intead of 50mm. (700mm down to 670mm)
The lighter weight of the sedan in the rear resulted in a drop of 10mm. (700mm down to 690mm). Both of these figures suit me fine.
The extra spring rate over stock has taken a lot of the slop out of the way the car moves on the road without making the ride harsh.
The wagon spring rate in the rear has eliminated the tendency to understeer & if you drive like a ***** & with excessive aggression, you'll get oversteer from the rear. Again, this suits me fine but it's very likely I'll remove the springs before passing the vehicle on to my daughter in 2 years time.
