Catastrophic Clutch Failure at 16000km !!!!!
  • Catastrophic Clutch Failure at 16000km !!!!!
    Ok I will put up the photos but I want to give a bit of a Back Story First.
    I was taken back when my fathers Skoda Octavia had a clutch failure at 16,000km. The car has only ever been driven by himself a 67 year old man, and his wife 66 years old. Both have a history of driving manual cars since the day they got their licenses. In my 37 years of knowing them both I can only recall one clutch failure when I was 5 and my father was towing a caravan up a steep hill in an old Kingswood (and the car had done far in excess of 100,000 km).
    VW Australia has claimed that the clutch failure will not be covered by warranty as the failure is caused by user error or abuse (this is what I have verbally been told). They are yet to confirm their position in writing as of the 24th of August 2012. In the mean time my father has no choice but to pay for the clutch as the car has already been 6 weeks at the dealers.
    The Photo above shows the catastrophic failure that has occurred to the 16000km young Skoda running a VW/Audi 1.8 liter TSI engine and five speed gearbox with a dual mass flywheel. This car was bought at the end of 2009 as their "good car", the car hardly gets used hence the 16,000km in almost 3 years.
    To repair this failure will cost $3500 which is over 10% of the cars original cost.
    Before I looked at the parts the dealer stated "I have never seen a Skoda with a clutch failure at or before 16000km". I asked "have you ever seen a clutch failure at 16000km?" he stated "No" (meaning other types of cars).
    The flywheel itself shows signs of failure i.e. excessive movement in the dual mass fly wheel. This may be caused due to heat, i.e. heating of the flywheel failing the internal components resulting in excessive play. All clutch systems produce some heat and design should be capable of addressing the environment that it is used in. VW Australia is claiming this is due to driver error or abuse. I find this very difficult to believe since the driver is 67 and has driven manuals his whole life without such failures.
    There is plenty of life left in the clutch plate with the friction material well above the rivets
    Imagine if disc brake rotors were designed to fail before the brake pads! Customers would not be happy having to constantly replace the rotors while the pads had not worn out.
    2 years before he bought this car he bought a manual Nissan pulsar; this car has done in excess of 100,000km and is still on its first clutch. This is what you normally would expect out of a clutch. Keep in mind these are driven by the same people.
    I am picking up the parts today to conduct further analysis and get a second opinion before I approach VW under the Trade Practices Act as advised by Victoria Consumer Affairs.
    I not only see this as a Consumer Affairs problem, but as a Safety Concern. If pressure plates can come apart like that at virtually idle (when the failure occurred the driver was pulling away from traffic lights) the damage it could cause at 6000rpm would be devastating.
    This is what can happen at hi revs, note this is from a skyline.
    Anyhow that is my rant, I would like to hear from anyone else that has experienced premature clutch failure.
    Roger
    Just updated the images so they work
      Never heard of one failing like that before especially at low kms. Was the car purchased new?
      MY2014 Skoda Octavia Ambition Plus Wagon, DSG, Capuccino, Tech Pack
      MY 2010 Skoda Scout Manual Silver -traded
        Make sure the input shaft gets checked . I currently have a car here that had a similar issue and the clutch was actually still engaged when it was driving burning the clutch plate out in less than 500kms .
          Never seen one fail like that before.
          If I hadn't read the post, and just looked at the images, I would've assumed driver abuse too.
          Your (parents') word against their's on this one, I'm afraid.
          '07 Transporter 1.9 TDI
          '01 Beetle 2.0
            Arrange an independent third party inspection and report by a licensed automotive engineer (not somebodies mate with a workshop). If your parents are in the RACV that would be one place to start.
            If you do not do that you will not have a leg to stand on in any future argument.
            This forum has allowed you to rant but ranting here will do nothing towards resolving the problem in a professional manner.
            My Škoda photos here
            Flickr : Blog
              Yeah. It looks like there has been CRAZY amounts of slippage. To get blueing on the plate like that, we are talking about 400C temps. Its not surprising that it failed.
              Im my opinion, it would not be a fault with the clutch but a fault with the gearbox input shaft (not allowing the friction disc to slide along the shaft) or with the release arm.
              There is also the possibility that the driver was driving along with their foot resting heaviliy on the clutch pedal. (not an accusation, just saying, it could achieve the same result).
              '98 Mk3 Cabriolet 2.0 8V
              '99 A4 Quattro 1.8T
                Fact is, unless the problem is VERY obvious nobody will be able to tell if the issue was a mechanical fault or driver problem - friction surfaces looking like that just indicate lots of slippage and nobody is going to prove one way or the other whose fault it is - just depends whose 'side' you are on.
                '99 A4 Quattro 1.8T
                  True but at this stage there is one "expert" (the dealership) saying one thing (driver fault) and the owner has nothing in response other than to say "I didn't do it". An independent inspection may well find something the dealership has overlooked or at least be able to demonstrate the the fault could also have been caused by mechanical failure rather than simply driver error. The OP has posted a massive bitch about how wronged they have been and how perfect the driving ability of their parents are but they have apparently not taken basic steps to ensure that their side of the argument can be proven and are instead relying entirely on the dealerships story without any sort on independent confirmation.
                  Flickr : Blog
                    Hi mate,
                    Hey I really feel for you guys...so sorry.
                    I dont mean to be rude, but is there any chance they may have been resting their left foot on the clutch pedal slightly while driving?
                    Please forgive me if that sounds bad, it is just that VW / Skoda will probably check that sort of thing.
                    I know of a guy who wore out brake pads early due to doing that with the brake pedal...
                    2018 Ralyee Green RS wagon. Fully optioned.
                    Previous vehicles:2015 Volvo V60 Polestar (my one detour from VW/Skoda!)
                    2013 Platin grey RS wagon / 2012 White Polo GTI / 2009 Black 125 Tiguan
                      As GLGDI states unless the failure is very obvious and has not been rectified by the dealer before inspection it is our word against theirs.
                      Tigger you are correct that ridding your foot on the clutch may result in slipping, however he has driven manuals his whole life without such premature failure.
                      Most of the travel in this car has either between between Bendigo and Melbourne, or visting me when I lived in Adelaide ( at least 3 trips to adelaide in this car).
                      I have collected all clutch pieces (flywheel, clutch plate, and pressure plate) from the dealer(preston motors epping), but mystriuosly the thrust bearing has gone missing despite my strict instruction that I wont all parts. I was going to get these indepently inspected, but without the thrust bearing it seems almost usless. Left with little choice but to bend over and suck it up.
                      You are correct that it is easy towear brake pads out if you rest your foot on the brake. The point here is generally that pads wear out before your brake discs snap into three pieces. You may however warp the disc which indicates time to change.
                      I have to check whether the gearbox is still out so I can get an opinon on the input shaft. Blueing of the clutch plate tangs is evident, however without the thrust bearing or inspection of the input shaft it still lies between user V manfacturing defect.
                        Firstly I will say that I feel for you and best of luck.
                        I drive a manual diesel and I have to say that I have been known to do some quick shifts from time to time, although never would i be found to ride the clutch. My car is coming up to 3 years next month and has 29000km on the clock. If my clutch were to fail like that, there would be hell to pay!!
                        Now with all due respect (and please don't be offended), that pressure plate shows a lot of overheating! I respect what you have said although I have seen plenty of people that "claim" they don't ride or slip the clutch, yet watch them at an up-hill sloped intersection or trying to park and I cringe with the abuse on the clutch. The older generation have a better chance of riding the clutch because they come from a generation of cars that had useless handbrakes!! I am just saying that maybe they were not aware of when they were slipping the clutch??
                        Driving with the foot on the clutch is another classic, especially given the clutch is so light in these cars. Some people may not realise they are doing it.
                        2015 MY16 Brilliant Silver Octavia vRS Wagon TDI DSG with Tech Pack, 19" black pack, pano roof and auto tailgate
                          I'm still curious as to how two people who have driven manual cars for years were apparently unaware of the massive slipping that must have occurred prior to the clutch failure. That clutch did not fail in a short drive to the local shops.
                          Just out of interest is there anything that the cars computer would have picked up as a fault code in this situation?
                          Flickr : Blog
                            MarkVRS, k1w1,
                            I agree with both your statements, but without inspecting all of the parts independently it is just conjecture.
                            Yes the clutch has been slipping probably very subtlety for a long time resulting in thermal cycling and thermal fatigue. The easiest answer is user error.
                            Another answer could be mechanical failure but all parts would be needed, particularly the thrust bearing to make a qualified judgement of the failure cause. Mysteriously it no longer exists.
                              Does anyone know any way to get the codes off? Do you need an obd2?
