A couple of things I've noticed about the heating/air-con controls in my MY11 RS and wondered if anyone has experienced similar.
I normally run the temperature setting at 22, occasionally knocking it up a notch to 23. The number in both dials (dual mode not set) respond correctly, but the screen on the nav/audio unit shows 23 on the passenger side, but still 22 on the driver's side! If I then take it to 24, both sides report 24 on screen; take it back to 23 and both sides show 23, as expected! It's clearly a minor bug in the HVAC control system, but wondered how common it may be? I'll certainly mention it to the dealer next week when I go in for my 15k service.
The other thing I've noticed is that if I switch from outside air to recirculate, the air-con switches on. This is probably standard behaviour, but was wondering if anyone knows if this can be changed via VCDS, so that the air-con is not cycled with this switch? I usually only switch to recirculate when behind a bus or a Hi-Ace van (ever notice that the petrol version of these things stink like an old kerosene heater?), so it's a bit annoying to have the air-con come on of its own accord in that situation.
