Water pump doesn't come with the genuine kit.
Always get prices from the dealership as a comparison. You'd be surprised sometimes. Expect to pay $250-$300 for the kit.
If going through the dealership, get an exchange water pump from them (and return the old one). They're around $150.
You'll need these: Laser Tools 4346 Volkswagen Timing Tool SET VAG Tool Garage Auto | eBay to lock the crank and cam, and accessory belt tensioner.
Should take most around 5-6 hours to do. Experienced guys can do them in around 4 hours.
Buy new bolts for the crank pulley. The heads of them are made of playdough.
Line it all up first, before you pull the crank pulley and lower covers off.
Check, and double-check your marks (i.e. rotate the crank 2 or 4 times with new belt on), before you start it.
Funds prohibitive...
