Tyre pressures on RS
  • Tyre pressures on RS
    What tyre pressures are people running on their RS?
    Checked my tyres for the first time the other night because the warning light came on. Had 38 psi in the front and 39 in the rear, so am assuming they were set at about 39psi all round by the dealer. I'm used to running about 36 in front and 32 in rear. What do others recommend for city driving?
    Cheers!
    now: 2024 Cupra Leon V
    '70 Alfa Romeo 1750 Berlina - project
    before: 2008 Octavia RS TSI manual sedan, sprint yellow, Stage 1 tune, 185kw.
    There is something wrong there.
    The warning light comes on when one tyre on a axle is flat (I think it needs to be about 10psi less than the other tyre on the same axle). It uses the ABS sensors to measure the wheel rotation speed, the flat tyre rotates slower.
    There was a case ages ago of somebody having the light come on after they drove through mud or something, presumably some dirt got in somewhere so maybe that was a possibility in your case.
    What I would do is get a decent gauge and check the pressures in the morning before you drive the car and heat them up. Assuming that they are all the same I'd reset the warning system as per the owners manual (that's the book boys never read) and keep an eye on things for a while. You may have a faulty sensor somewhere.
    As far as pressure is concerned I run 36/36, don't know why I just always have on every car.
    My Škoda photos here
    Flickr : Blog
      Yeh, the light recently kept coming on in mine and I thought it was faulty ..... turns out I had a slow leak in the rear left.
      I should learn to trust it.
      Running 32/36
      Don't carry much around except me.
      Joy Toy: 2010 Skoda vRS - Metalic Black - Liftback - TSI - 6sp Manual - Leather - Sunroof - Fiscon Plus
        The optimal tyre pressure can be found on the inside of the fuel filler flap (thats coming from a book boy) but this is based on most efficient tyre wear and supposedly comfort.
        Personelly i run them a couple of PSI higher than recommended as this was recommended to me by a friend as it helps with fuel consumption. I have not done any investigation on this but generally it appears most people run at a slightly higher pressure.
        K1W1 is 100% right when he says get a decent tyre pressure gauge and check them from cold as the petrol stations tyre pressure gauges are just crap.
        I have had my warning come on once and i pulled over and gave the tyres a usual kick and all appeared to be fine. Reset the sensor and set off again and all has been fine since. Maybe i had driven through some mud or something that threw it out.
        PS i am running 32 all round on mine.
        MY11 Octavia RS; 2.0 TSI DSG; Liftback; Sprint Yellow; Sat Nav (standard Fit now); Front Parking Sensors; Supreme Onyx Leather; Bluetooth and Alarm.
        Ordered - 8th Jun 2010; Built - 31st Aug 2010
        Delivered 12/11/10 - 12.30.
          36 front, 32 rear.
          MY11 Octavia RS 2.0lt TSI DSG Liftback - Candy White
            Almost same as K1W1, I run 38/36 on my RS. Use a hand-held gauge to check it at home every fortnight.
            Was told by my local tyre guys years ago you can easily add 15-20% to the manufacturers tyre placard recommendation to prolong tyre life and improve fuel economy.
              Not a good idea. The low profile tyres will appear to be full using the kick test even when they have less than 20psi in them. Carrying a decent gauge and checking the tyres when the warning comes on is a way better idea.
              The placards are there for legal reasons and afaik the pressures quoted are generally set on the side of comfort (softer ride) rather than tyre life or fuel consumption. My tyre shop has always told me to run around 36psi regardless of the placard and generally I do and generally I get pretty good tyre life, reasonable fuel consumption, only occasional punctures and no complaints from the back seat so that's what I do.
              Flickr : Blog
                Perfect timing for this thread as I just picked up my RS yesterday and went straight to the petrol station to check the tire pressures.
                When I looked at the placard I was most confused. I hadn't come across a FWD car before that had higher pressures on the rear than the front. I took it's word though and made it 33/38.
                After reading this I might head back and make it something more like 38/36. 99% of the time the car will basically be empty other than me driving and I want to take care of the continental 18's as I can't imagine they are a cheap tire!
                Skoda Octavia RS TSI Liftback MY11 - Race Blue
                  i initially had 32 fr & 30 rr, & didn't like it - felt lethargic!
                  pumped it up to 34 fr & 36 rr. much better.
                  i put 36 allround now. am happy with that.
                  i'm still on the hunt for a good tyre inflation system i can keep in my garage. i hate having to depend on the ones in the service stations. most of the time they don't work or dodgy. the ones that do generally work r further way, meaning by the time i get there, the tyres have already warmed up!!!
                    Yeh, exactly. I looked and looked and psuhed after the sensor went off for the 3rd time, wasnt until I stuck a gauge on it that it showed 18 !!!!!
                    Appearance and feel is a useless gauge on low profiles.
                      Thanks for all the replies. Not sure if the sensor is faulty, but after I checked all the tyres and put an extra 1psi in the front the warning light went out and hasn't come back on since.
                      I've got a compressor in the garage and was planning to check the tyres tomorrow with my own gauge. I'll put 36psi all round and reset the sensor.
                        Again I think that's strange. From memory the sensor light on the dash stays on until you manually reset it.
                        Flickr : Blog
                          Yes you must push and hold the button in until it resets.I cant believe the high pressures people are running, it must be wearing out the centres for sure. It would also take along time for the tyres to heat up and get sticky on a cold day.
                          2014 MY14 Corrida Red Elegance Wagon TDI
                          2009 MY10 Race Blue RS Wagon TSI 6 sp. manual. (Gone)
                          2011 MY12 Yeti 77 TSI DSG.
