Finally got the chance to drive the RS since the missus uses it daily for her commute to work and I have realised that the reading on the Digital Oil Temp is different from the gauge.
For example, the other day the digital readout was telling me that the car temp was sitting at 102 degrees, but you look at the gauge and it's telling you it's a whisker over 90. The digi temp went up a few degrees but the gauge still had the same readout.
I'm not overly concerned by the issue, but curious as to whether anyone else is experience the same thing. If so, I assume the digital gauge is going to be the more accurate of the two? I just would have thought it would be running off the same sensor so they should both be giving the same result?
Cheers!
Cheers!
