Bolero expertise required!
  • Bolero expertise required!
    Two questions.
    1. I've somehow managed to lose my 'station list' when on am. It still highlights on FM but on AM the station list option does not light up. Any ideas??
    2. Can Bolero play am MP3 DVD?
    MY2014 Skoda Octavia Ambition Plus Wagon, DSG, Capuccino, Tech Pack
    MY 2010 Skoda Scout Manual Silver -traded
    Originally posted by PassatB6 View Post
    Two questions.
    1. I'll have to look at the manual but it's fairly straight forward to put it back.
    2. No it's a CD player only.
    My Škoda photos here
    Flickr : Blog
      The process of searching for and storing the radio stations
      Manual search
      – Turn the Set button in the RADIO main Setup or press on the function
      key . The scale of the selected frequency range is inserted in
      the frequency band in the lower part of the display.
      – Briefly press the set button to terminate the manual frequency selection
      and to display once again the function keys.
      Storing a radio station on a displayed station key
      – Continue to press one of the six station keys to displayed in
      the RADIO main Setup until a signal tone sounds. The currently heard
      radio station is then stored on this station key.
      Deleting a radio station from the memory list
      – In the RADIO main Setup, press the function key to open the
      memory list.
      – Press the function key behind the station you wish to delete.
      – Confirm the following safety interrogation by pressing the function
      key to finally remove the station from the memory list.
      If the currently heard radio station is already stored in the memory list, the memory
      space number is displayed behind the description of the frequency range (FM or
      AM).
      Use the Setup Radio main Setup, to determine which of the six station keys are to
      be displayed in the main Setup RADIO.
      Flickr : Blog
        On the older Audience radio, once you're on the station you want you just hold the button next to the position you want it in; surely the Bolero is similar?
        Mine: Silver 2006 Volkswagen Golf Sportline 2.0FSI 6M (with a sunroof)
        Parents': Candy White 2008 Skoda Octavia RS 2.0TFSI 6M Liftback
          Thanks for the replies but doesn't 'Station list' refer to stations currently in reception area not stations in memory. Or am I wrong??
            The "Station List" button is only available in FM, at least that's how it works in my car.
              Thats interesting! Maybe I never had AM Station List in the first place. Not sure why that would be though.
                If you are talking about the 6 buttons on the screen in the radio display I have 3 AM and 3 FM on mine.
                Flickr : Blog
                  No, theres actually a 'Station List' button which is visible in FM but is not highlighted in AM. It should give you the list of stations in your current area. Mine (and Gaz) Bolero doesn't show Station List button in AM mode. No apparent reason for this as far as I can work out.
                    My Station list is greyed out in AM at least but seeing as I only listen to 2 or 3 of the programmed stations or SD card music I hadn't actually noticed before now.
                    Flickr : Blog
                      Looks like the consensus is Station List doesn't work for AM, so I guess its normal to be greyed out.
