Started the car, backed out and within about 10sec got the coolant warning light. Turned off the car, looked at the reservoir and it was just below min...or possibly over it, but it was the slope the car was on. So had some deionised water, tipped a little in, and it went up to Max pretty quick.
Then thought....I bet this car has some reason like everything else where I shouldn't have done that. Sure enough the manual says use the G12 stuff for topups. At which stage did we get where cars can't even be topped up with a tiny amount of water anymore?
It says you need a minimum of 40% coolant and higher is for really cold countries. I'm guessing since the car is 18mths old that it is probably much higher than that conc in it, but who knows what they do. I'm wondering why it was so low in the first place, no obvious signs of leaks anywhere. Anyway I'll run it over to Richmond Skoda in the morning and see what to do. I guess worse case scenerio, I could suck a little coolant out and add more concentrate in, but in the long run I think it would make bugger all difference if the conc is already higher than needed in Oz. My real worry is why it was at min anyway.
