Engine Oils use approved oils only.
VW504.00 VW507.00 is backward compatible so it can be used in all previous petrol and diesel engines with older oil specification with some exemptions (not related to Skoda engines).
Official VW,SKODA List of Factory Approved Engine Oils
Replace latest at every 15,000km or 12months whatever comes first.
These are on the list and are available from all good car parts stores.
Penrite Enviro+ 5W30
(in 1L or 5L bottles - fully imported oil made overseas) is available from all good auto parts stores and for $76.00 RRP is the cheapest ($60 if you shop around)
Shell Helix Ultra Extra 5W30
(in 5L bottles) is available from Nissan dealers and Super Cheap Auto ($75/5L)
Mobil 1 ESP 5W30
tel.1800 033 863 for your local Mobil oil distributor (supplied in 20L drums only)
Castrol SLX PowerFlow Professional Formula 5W30
from the dealer – the most expensive option. 1L for top up will cost you around $30.00
Gear Oils
Unlike engine oils the different brands of transmission fluids shouldn't be mixed together and the same apply to gear oils.
For 6speed manual gearbox
Penrite Gear Oil 70 SAE 70W-75, API GL-4 (in 2.5L bottle) $45.00 RRP
Red Line MTL Gear oil 70W80 API GL4 (1US Gallon)
Diff oils
Penrite Transaxle 75 SAE 75W-90 API GL-5 (in 2.5L bottle) $29.00 RRP
Transmission Oils
Use only genuine ATF and DSG fluids.
Replace DSG fluid in 6 speed DSG transmission every 60,000km or 48 months, whatever comes first.
Power Steering fluid
Again use only approved power steering oils. Penrite makes power steering oils for all VAG cars. Most likely you will have electromechanical steering that doesn’t have the reservoir for topping up, so you will not need it.
Coolant
Use genuine VW coolant only (G12+) VW states lifetime fill, I suggest replacing it after 5 years.
NOT APPROVED by VW
Meets, Made to VW specification - that is what the oil manufacturer saying on the label and IMO it would be a mistake to use it in your late model Skoda with diesel engine and the DPF especially if there is Penrite Enviro+ 5W30 that will cost you the same money as any other not approved synthetic oil.
VW SERVICE FLUIDS AND GREASES FOR VARIOUS TASKS
VW 767X
Synthetic grease for lubricating sliding roof mechanism and guides
FUCHS Renolit SI 300M
KLUBER Polylub GLY
VW TL 521 50
Synthetic grease used as a mounting aid for brake cylinder bolts
Renolit LX-PG 2
VW TL 735-Y
Special grease with solid lubricant used for the lubrication of spline shaft CV joints to avoid fretting corrosion specially for the T5 Transporter
Renolit MP 735 AZ
VW TL745
Low temperature optimised grease for lubricating door locks, window lifters, seat mechanisms and pedals.
Renolit FN 745/94
VW TL 521/41
Lock de-icer resistant grease for lubricating door locks
Renolit ST-CM 2
VW TL 735
Multipurpose grease used for lubricating wheel bearings.
Renolit MP 735
VW TL 735-X
Special grease for general lubrication of spline shafts of the CV joints to avoid fretting corrosion.
Renolit MP 735
DO NOT POST OFF TOPIC, THIS THREAD WILL BE CLEANED FREQUENTLY TO KEEP IT USEFUL
Mobil 1 ESP 5W30
Gear Oils
Diff oils
Transmission Oils
Coolant
NOT APPROVED by VW
VW 767X
KLUBER Polylub GLY
VW TL 521 50
Renolit LX-PG 2
VW TL 735-Y
Renolit MP 735 AZ
VW TL745
Renolit FN 745/94
VW TL 521/41
Renolit ST-CM 2
VW TL 735
Renolit MP 735
VW TL 735-X
Renolit MP 735
