I can get A2DP from my iPhone through my Fiscon.
I only found out because for some reason (very occasionally) after I hang up a call I start getting iPhone music through the Bolero. As long as the phone is in my pocket and not connected to the MDI in the glove box it's easy enough to stop and I must admit that it only happened two or three times and hasn't for ages.
BTW there are two other things about the Fiscon that are worth mentioning.
If you have a large number of phone numbers (I probably have close to 500 contacts many with multiple numbers and email addresses, etc) the Fiscon Bluetooth takes way longer to start up than the Bolero music from an SD card. Makes the SD card look fast actually.
When a call comes in it shows on the Bolero screen and an "unknown number" until you answer it. Once you press the answer icon the number shows or if the person is in your address book their name shows. If you want to screen calls while you are driving the Fiscon is not good.
